Author Topic: 1969 rear leaf spring cup front eye bolt & nut part#3892754 & 9417614  (Read 9801 times)
Edgemontvillage
Re: 1969 rear leaf spring cup front eye bolt & nut part#3892754 & 9417614
« Reply #15 on: October 24, 2019, 02:53:56 PM »
Surprisingly few posts on this question. I reached out to "JM" and he stated the bolt, washers and nut should all be manganese phosphate.
x66 714
« Reply #16 on: October 24, 2019, 08:23:47 PM »
Mine would be a good one to look at but I had to use the nut, bolt, & forward spring hanger for the body cart to bolt to. It's at the body shop at the moment. That hdw was absolutely perfect on that car. I have to go there in the morning as they're painting the front clip. I will see if I can see the hdw when I'm there...Joe
Edgemontvillage
« Reply #17 on: October 24, 2019, 09:49:20 PM »
Thanks.
john302
« Reply #18 on: October 26, 2019, 04:17:52 PM »
On all the original cars that I have seen the nut is silver and all other pieces are black/grey phosphate . Can supply photos to back this up.This is the way I have done it on all the restorations in the past. The nut is alittle thicker and square cut compared to a standard hardware store nut.
Edgemontvillage
« Reply #19 on: October 27, 2019, 03:23:18 AM »
If you have any original photos of this hardware to post that would be helpful.
Edgemontvillage
« Reply #20 on: November 04, 2019, 03:00:17 PM »
For those who've contributed to this thread, thank you! From photos and other input I've received I've concluded the following:
Eye bolt, flat washer and lock washer - manganese phosphate (dark)
Nut - silver/clear zinc or natural
Here is the now restored hardware for my car:
« Last Edit: November 04, 2019, 03:41:56 PM by Edgemontvillage »
