Author Topic: Keep blowing CLK-LTR/CTSY fuse  (Read 7772 times)
1967RS/SS
« on: February 16, 2018, 12:29:42 AM »
I keep blowing the CLK-LTR/CTSY HAZ 20 amp fuse.  While trying to track down the problem and instead of burning through fuses, is there another way to test?
I thought it was the door jamb pin switch because the threads are stripped so I put a nut on the backside of the switch and cleaned the paint around the switch but it still blows the fuse.
1967 RS/SS L-48
Van Nuys 01C
Joseph
Re: Keep blowing CLK-LTR/CTSY fuse
« Reply #1 on: February 16, 2018, 02:21:58 AM »
my 67 had that problem. remove the orange wire from the lighter and see if the short goes away.
Kelley W King
« Reply #2 on: February 16, 2018, 12:33:09 PM »
If it is constant pretty easy to find, if is intermittent might take a while. If it is shorted some testers beep when used. I connect it and while it is beeping go check the various devices and if the  beep varies I know I am close. For the hearing impaired a light works also.
69 SS L78
67 SS Chevelle
64 Corvette
66 GTO Tiger Gold
77 Trans Am Special Edition
1967RS/SS
« Reply #3 on: February 22, 2018, 08:51:41 PM »
I finally found the issue.  I had a single contact bulb in a two contact socket.  Installed the right bulb and my sail panel and courtesy lights are all lit up now!  Thanks and on to the next issue
1967 RS/SS L-48
Van Nuys 01C
Joseph
