Author Topic: Starter question  (Read 8447 times)
go2fast
Starter question
« on: November 23, 2005, 11:08:49 PM »
I have a '68 that used to have a turbo 350. I'm replacing it with a muncie, but I'm having a starter problem. I have a 621 bellhousing with an 11" clutch on a 14" 168 tooth flywheel (same size at the old flex plate). Everything fits but the starter. It's not even close. The nose is too big for the bellhousing.  It's the original 327 with the offset starter bolt holes. Do I need a different starter? I thought all the 168 tooth starters with the offset holes where the same.
4myz
Re: Starter question
« Reply #1 on: November 24, 2005, 12:49:15 AM »
YOU NEED A STARTER THAT HAS THE CAST IRON REAR HOUSING
go2fast
« Reply #2 on: November 24, 2005, 02:29:38 AM »
What were they used on? How can I tell it's the right one?
