Author Topic: YS Coil Springs  (Read 4017 times)
HustleRussell
YS Coil Springs
« on: January 28, 2018, 12:56:40 AM »
I replaced the front springs on my 68 rs today.
Installed HA. The code on the old springs is YS.
I couldn’t find any info on them. Is this the
correct code for base 327 and manual transmission?
I believe this car was a base 327 and manual trans
from the factory. Thanks in advance.
Russ
68 RS
69 SS
Re: YS Coil Springs
« Reply #1 on: January 28, 2018, 01:02:44 AM »
Depends on your other options. There are 68 spring table charts at this link.
http://www.camaros.org/suspen.shtml#spring
Go to the section on Spring Usage Tables
Here is page 1
http://www.camaros.org/images/pages/chassis/68_spring_chart_1.jpg
HustleRussell
Re: YS Coil Springs
« Reply #2 on: January 28, 2018, 02:01:36 AM »
Awesome chart. I’m seeing YS springs as part of F41.
My 68 has speedo piercing for Saginaw transmission
So it could have come with Base 327 or L30?
The man I purchased car from did say he stripped
The 12 bolt rear end.
Russ
68 RS
69 SS
Re: YS Coil Springs
« Reply #3 on: January 28, 2018, 02:04:13 AM »
If it had a 12 bolt originally, it was probably an L30 car.
More on the L30 at this link.
http://www.camaros.org/l30m20.shtml
