I have drag raced a ton of F bodies with mono leaf springs, what I do know for fact, is that if it breaks, it wont be there,they break, or actually crack, in the axle perch area, specifically where the rubber cushion ends at the spring itself. What happens is water will sit and rust a line across the spring perpendicular,causing a stress riser. Looking at the shape of the spring looks like there may be a ride height problem ?
