Author Topic: X Codes  (Read 13082 times)
X33RS
Re: X Codes
« Reply #15 on: February 13, 2018, 08:20:52 PM »
I can offer the following related to your question based on my car;
LOS Van-Nuys Indy pace car (Obviously NO Z11 on the trim tag)
Fuel Tank sheet certianly had Z11AA typed in the lower section.
I still refer to it as a Z11 Pace Car, wether it was NOR OR LOS, it still is equipped with the package and content.
Jim, I'm assuming the Van Nuys plant did not write codes on the bulkheads?
X33RS
Re: X Codes
« Reply #16 on: February 13, 2018, 08:29:47 PM »
I see a lot of people referring to the 69 Camaros using the "X Code" I.E. X11, X33, X77. I know that the X Codes didn't start showing up on the Norwood trim tags until the first or second week of Dec. 68. My question is would a car that was built before that or even the LA built cars that didn't have X Codes still be called ( Let say an LA built 69 Z/28 an X33) ?  Or does it have to have that code on the trim tag for that?
I think I understand what you are trying to convey with your question.  My feeling is that the X code slang thrown around originates with the Norwood cars and their trim tags.  So when I hear the term, I automatically picture in my mind that it's at least a Norwood built car from 12B 68 and beyond.     Anything else and we are talking about Pre 12B Norwood, or a Van Nuys production run Camaro.
But it can all be interpreted any way you see fit.  No right or wrong.  I suppose a Van Nuys Camaro can be referred to as the same thing if there is some sort of paperwork to confirm it, but in my mind it's still more of a trim tag thing and only 12B and beyond Norwood cars fit that idea that the description was intended for.
WorkinProgress
Re: X Codes
« Reply #17 on: February 13, 2018, 09:01:32 PM »
The X crayon mark is usually found behind the pass side of back seat, near where the vinyl overhang of the package tray is glued.
        - Warren
Re: X Codes
« Reply #18 on: February 13, 2018, 09:36:44 PM »
Fisher did not always put partial X codes there. I have seen interior paint codes such as DK GRN or BLU in the same area.
HOT3O2
Re: X Codes
« Reply #19 on: February 13, 2018, 10:53:07 PM »
Did the LA plant use the X Code terminology like the Norwood plant? Was the X Code found on any paper work? (LA or Norwood)
Rick
69 RS/Z28
Re: X Codes
« Reply #20 on: February 14, 2018, 12:09:23 AM »
The body tag was of no use to Chevrolet Assembly; they did not reference it. Body and Chassis Broadcast Copies were generated by Chevrolet when the completed body was released to final assembly. X codes were not relevant to Chevrolet; never seen them on any paperwork.
X codes refer to specific body build configurations. It is likely that both Fisher Body plants used the same engineering information to build Camaro bodies. For some reason, Fisher made the decision to add the info to Camaro body tags late Dec 1968 but only at Norwood.
There had to be other means of conveying Fisher Body build information at both plants. Certain options required slight differences in body fab; RS, dual exhaust, spoilers, etc. Carefully media blasting a body often reveals option codes written on the firewall in grease pencil: M20, N10, Z22, etc. Maybe that's all they did.
BTW the firewall graffiti prominently seen on some restorations is inaccurate. The writing was done on the uncoated body and all of it was covered during firewall blackout. Over time, the paint can flake off the crayon and some of it becomes visible. On occasion, I have seen the assembly sequence number written on a body after paint. Workers were supposed to remove it.
HOT3O2
Re: X Codes
« Reply #21 on: February 14, 2018, 03:13:07 AM »
Great information. Thanks William.
Rick
69 RS/Z28
