Differential: complete rebuild to include new 4.10's. After around 49 years, the 88's are coming out. I still the possess the original GM 4.10's, but they are to remain boxed up. C clip eliminators are coming off, housing ends are to be repaired . Yoke inspected. Also getting fitted with a set of replacement springs from Mr. Harris. And circa 70's Lakewood slappers. Rear drums original, well within specs, shoes and hardware were replaced around 1990, I think, but present no signs of use...dirty. BP getting blasted and resprayed, new brake hardware and cylinders. Bob also hooked me up with a pan for the 302. Only difference I see in the springs is 1 dimple on 1 leaf: L&R.
Bushings still in great shape, but will be boxed and shelved with the others. I may post a pic of the later, if I find a part#, didn't look. I'm aware no rocker trim or push bars on the bumper,,,doing Day 2. On the fence re-pop polys vs. BFG's. Considering the originals are in storage, but not safe to drive on, I'm leaning towards the BFG's. If the car was just trailer bound, I'd mount the originals. Two shows next year, and it's seeing street duty.
