Welcome,
Guest
. Please
login
or
register
Did you miss your
activation email
1 Hour
1 Day
1 Week
1 Month
Forever
Home
Help
Search
Login
Originality
'68 Camaro Inst cluster bulbs/ sockets
« previous
next »
Print
Pages: [
1
Author
Topic: '68 Camaro Inst cluster bulbs/ sockets (Read 6029 times)
L78racer
Member
on:
December 20, 2017, 05:47:35 PM »
Question on the two different bulb sockets for the Gen and Brake lamps on cluster for car with no gages. Are these gray sockets and or bulbs something special with maybe different candlepower bulbs or ? Thank you. Paul
Tweet
Logged
Hero Member
Re: '68 Camaro Inst cluster bulbs/ sockets
Reply #1 on:
December 20, 2017, 06:11:20 PM »
I'll take a good guess.....this was a design change because with the shorter black sockets used on 67 clusters, it is almost impossible to reach up and get a good grip to remove either of them. Been there....done that.
I notice the much better designed ground band connecting the high beam socket to the cluster body.
Logged
Hero Member
Reply #2 on:
December 20, 2017, 06:29:09 PM »
Good guess Mike, but I don't think it's correct since the 1967 AIM shows the gray sockets (P/N 3882798) for the Generator and Brake warning lights as well. The operators manual shows these two lights were 3 candle power as opposed to 1 candle power for the rest of the lamps, so that may have had something to do with it. This isn't something I've ever researched!
Logged
Hero Member
Reply #3 on:
December 20, 2017, 06:42:17 PM »
Hi Ed,
I just checked my 67 AIM and I see 12/B3 is dated 5/67. My 67 05B convertible gauge cluster has a date of April 67 so perhaps the socket was changed to the gray one by late May? My 67 cluster definitely has the short black connectors. The last time I changed a directional bulb I had to lower the steering column because I could not get the socket loose (my fingers reached it but not good leverage).
Logged
Hero Member
Reply #4 on:
December 20, 2017, 07:19:30 PM »
Mike, that 5-1-67 date is in regards to note 14 (circuit drawing revised) and note 15 (screw and washer drawing removed), so it has nothing to do with the socket. If it did, there would be a note next to item 8. And you can't go by dates in the AIM since it's not necessarily the date the change became effective. It was just the date the note was entered into the AIM. The actual change could have been much earlier or much later than that.
Logged
L78racer
Member
Reply #5 on:
December 20, 2017, 07:28:41 PM »
thanks all for the replies.
Ed, by operators manual are you referring to the owner manual? i never thought of looking there. is there a number on the bulb(s) for the 3 cp and the 1 cp bulbs? Paul
Logged
Hero Member
Reply #6 on:
December 20, 2017, 08:03:33 PM »
Yes Paul, the Owners Manual. The Generator and Brake warning lights (P/N 455626) are shown in the Owners Manual (page 69) as number 1816 (3CP) bulbs. The others have different part numbers. 1445, which is a 1CP, and 194, which is a 2CP.
Logged
L78racer
Member
Reply #7 on:
December 20, 2017, 08:33:20 PM »
Thank you all very much. Merry Christmas! Paul
Logged
PURESS
Member
Reply #8 on:
December 23, 2017, 02:07:43 PM »
Paul...Love the tree... Merry Christmas! Scott
Logged
Print
Pages: [
1
« previous
next »
Originality
