Author Topic: Small block with th400  (Read 5280 times)
HustleRussell
« on: December 10, 2017, 01:50:51 AM »
I’m thinking about installing a 350 smallblock, th400 and 12 bolt rear end in my 68 rs for drag strip duty. Later on the smallblock probably will get changed over to a bigblock. My question is should I use bigblock motor mounts on a smallblock with a th400 crossmember and th400 driveshaft? So when I change over to bigblock nothing has to change, except engine?
Russ
68 RS
69 SS
Re: Small block with th400
« Reply #1 on: December 10, 2017, 03:38:38 AM »
If you have s big block radiator & shroud , then yes, I would go ahead and and get the bb frame stands
If you do not have a bb radiator with the bb frame stands, then you will either have to leave the shroud off ( it will run hotter and be a constant safety concern with the car running). Or, modify the shroud.
Or, use the sb mounts & radiator and modify the trans mount.
If it is a true drag only car, then, that is what sawzalls and torches were made for. If you don’t run a power booster, I would think that you could run the small block frame mounts shroud, radiator, and modify the trans x member. I see bb and sb shroud setups done all the time on these Ebay clones. A lot of those bb cars run a th350 though. Hope this helps and I hope there is no misinformation. 68 frame mounts are different then a 69.
« Reply #2 on: December 10, 2017, 07:03:29 AM »
My opinion if you are thinking big block down the road, just simplify things and go that route now.
HustleRussell
« Reply #3 on: December 10, 2017, 06:52:43 PM »
Thanks for the advice. The 68 currently has a six cylinder radiator and no shroud. So I’ll purchase both of those for big block. Wanting to start off with 350 engine first because I’ve got one that’s race ready.
Russ
68 RS
69 SS
