Author Topic: No brake lights or 4 way flashers?  (Read 3714 times)
marriest
  • 1969 Camaro Pace Car, 396 cu / 325 hp, #matching
« on: December 01, 2017, 04:48:29 PM »
My 69 Camaro brake lights quit working. I checked the switch and it is ok. Turn signals are working. .
Brake light bulbs ok
Running lights are working
Brake lights not working
4 way flashers not working
What does the silver tridon dot 552 do in the fuse block?
Help
Terry
Terry
Re: No brake lights or 4 way flashers?
« Reply #1 on: December 01, 2017, 05:23:55 PM »
Terry, did you check the fuse?
marriest
« Reply #2 on: December 01, 2017, 06:28:46 PM »
Fuse has continuity but replaced anyway, surprise lights are working. THANKS!
Always suspect the obvious.
Terry
Terry
« Reply #3 on: December 01, 2017, 07:41:22 PM »
The fuse block flasher unit is for the 4-way flashers, there's another unit up under the dash clipped to the support rib that does the turn signals.
Everett#2390
  • ^Bess
« Reply #4 on: December 03, 2017, 10:05:55 PM »
Each circuit has its own power from fuse panel.
Brake lights goes through turn signal switch, so you might pull back on t/s handle as this action may make contact in T/S switch as bushing may be worn out due to weight of steel handle.
But, I would wager if you get emergency lights working first, brake lights will work.
