Author Topic: 9N5672x7 - Muncie Transmission Case  (Read 11633 times)
« on: November 08, 2017, 05:58:43 PM »
Your Muncie M20 4-speed transmission case is on eBay...
Transmission case is stamped: 19N5672x7  P9T18A  (x = ?)
Seller id: howard7539
Seller location: Cincinnati, OH
Possible VIN: 124379N5672x7 or 124679N5672x7
https://www.ebay.com/itm/1969-Camaro-Norwood-M20-Muncie-4-Speed-Case-3925660-P9T18A-Broke-Ears-Extra-Case/332402022112?_trkparms=aid%3D222007%26algo%3DSIM.MBE%26ao%3D1%26asc%3D20140725133649%26meid%3D208b7e2933fe4277b9ff36bc4994e311%26pid%3D100276%26rk%3D3%26rkt%3D4%26sd%3D232541104364&_trksid=p2060778.c100276.m3476
Re: 9N5672x7 - Muncie Transmission Case
« Reply #1 on: November 08, 2017, 06:18:30 PM »
Boy, that's a tough one. It's not a 0 because it's not high enough. It's not a 2 because the leg at the bottom isn't flat. It's not a 3 or a 5 because it's closed in on the left. I don't think it's a 6 either (compared to the other 6). It MIGHT be an 8??? If it is, it's either 124379N567287  or 124679N567287
« Reply #2 on: November 14, 2017, 06:12:51 AM »
It has to be an 8. Nothing else fits.
jdv69z
  • 69 RS Z/28 52E
« Reply #3 on: November 14, 2017, 01:33:16 PM »
So what do you do with this case? Fix it? Is that doable?
Jimmy V.
« Reply #4 on: November 15, 2017, 09:33:20 PM »
Those ears can be repaired. With skill, you could barely tell.
Kelley W King
« Reply #5 on: November 17, 2017, 03:58:54 PM »
If you need THAT case just find 2 ears, bolt it all to a bell housing and weld. We have done several. Some creative grinding and you can hardly tell.
69 SS L78
67 SS Chevelle
64 Corvette
66 GTO Tiger Gold
77 Trans Am Special Edition
« Reply #6 on: November 17, 2017, 04:29:52 PM »
Yup, the seller states he/she will give you a donor case in the listing description...
"I will give you another case with 2 good ears so you can repair this rare Norwood one."
« Reply #7 on: November 18, 2017, 08:38:04 AM »
It probably wouldn’t be cost effective to repair it, unless it’s for your car.  If someone can’t repair it on their own, it will probably cost $200 or more for a top notch repair. Of course much less if you can do it yourself.
« Reply #8 on: December 18, 2017, 08:13:08 PM »
Sold 12-18-17 for $100.00
Kelley W King
« Reply #9 on: December 18, 2017, 09:26:52 PM »
Dang I would have gone that with the extra ears.
69 SS L78
67 SS Chevelle
64 Corvette
66 GTO Tiger Gold
« Reply #10 on: May 01, 2018, 06:14:30 PM »
IF you use a pneumatic needle scaler to dimple the surface you can get the look of cast aluminum easily.
