Author Topic: P/S pump  (Read 7756 times)
cfar
  • L30/M35 Tuxedo Black
P/S pump
« on: February 02, 2007, 10:55:11 PM »
I found the pulley numbers on this site.
5698119 is the number on the pump itself-no numbers on reservior.
21 198 ND  with a M over a W in a circle
There is also a a symbol like a bar with 1 20  in it.
What would be the date code and what does a 5698119 pump fit?
Frank
11C 1967 - Born on date estimated Nov 15th,1967 LA Plant
In Service Jan 18th, 1968  Hollywood CA
Re: P/S pump
« Reply #1 on: February 03, 2007, 01:57:35 AM »
Frank -
   Where on the pump did you find your numbers? I checked mine and I don't see any numbers on the pump or reservoir. Of course, it's pretty grimy down there.
cfar
Re: P/S pump
« Reply #2 on: February 05, 2007, 02:47:01 AM »
Frank -
Hi Paul,
They are on the main pump body-you have to remove the resvoir to see them.
I am trying to do a total number doc on this car on everything I can find-since I knew its history from the original owner.
Frank
Re: P/S pump
« Reply #3 on: February 05, 2007, 04:16:50 AM »
Frank -
   No wonder I didn't see any numbers! Sorry, due to their location, I'm not going to be able to confirm your numbers at this time. "If it ain't broke, don't fix it"   ;D   Good luck with your restoration!
cfar
Re: P/S pump
« Reply #4 on: February 06, 2007, 03:32:00 AM »
I understand the broke thing ;D
 but i figured since I'm there I'll reseal it and get the numbers while i'm at it 8)
Plus it may help others
Re: P/S pump
« Reply #5 on: February 06, 2007, 06:40:31 PM »
Hi Frank -
   I was referring to myself with the "broke" comment.  I think you're are doing it the right way.  That's the way I'm planning on doing it when my children get older.  I just meant I wasn't going to take it apart at this time to check those numbers.  Carry on with your restoration!   :)
cfar
Re: P/S pump
« Reply #6 on: February 07, 2007, 04:32:09 AM »
Thanks and you'll get there in the future Paul ;D
