Author Topic: cooling fan and sticker mark on trunk deck  (Read 12174 times)
Tx-Z 302
« on: October 28, 2017, 09:21:58 PM »
this fan was in what was left of my trunk in a box with other odds and ends parts, not sure how to tell if its right or a production date, all i find is an "H" on the hub area and "front".    the deck lid has glue for a sticker, im not sure if it signifies anything or if they all had a sticker placed there?
Chris W
Tx-Z 302
Re: cooling fan and sticker mark on trunk deck
« Reply #1 on: October 28, 2017, 09:23:28 PM »
more pics
Chris W
Tx-Z 302
« Reply #2 on: October 28, 2017, 09:24:19 PM »
more pics
Chris W
« Reply #3 on: October 29, 2017, 02:07:23 AM »
'H' is for Hayes-Albion, which was an OE supplier to Chevrolet. More here: http://www.camaros.org/coolingsystems.shtml#fan
Some fans were unstamped whereas others had a number on the blades. That article via the above link should help ID yours.
Trunk lid adhesive residue is either from the jacking instruction or positraction (if that RPO was fitted) warning label.
« Reply #4 on: October 30, 2017, 11:34:46 PM »
Following above reply, just checked the trunk lid on my car and the jacking instruction label is in the center, like the one in your first picture, and the positraction warning label is on the right (passenger) side. The 1969 AIM also shows this arrangement under G80 sheet A1.
« Reply #5 on: October 31, 2017, 03:14:06 AM »
Here's what my original stickers look like under my trunklid
Tx-Z 302
« Reply #6 on: October 31, 2017, 03:26:44 AM »
Thanks for the help guys
Chris W
plumL78
« Reply #7 on: November 03, 2017, 12:13:11 PM »
That's the correct L78 and Z28 fan. Don't let it grow legs
Kelley W King
« Reply #8 on: November 03, 2017, 03:11:05 PM »
Does that 5 blade fan fit other engines? It seems I have seen more of them around.
69 SS L78
67 SS Chevelle
64 Corvette
66 GTO Tiger Gold
77 Trans Am Special Edition
« Reply #9 on: November 03, 2017, 07:48:09 PM »
It does have the appearance of the correct L78/Z28 '68 fan blade, but the proof is the bolt circle (should be 3-1/4")and clutch openings. The lo-po 5 blade with the 3.00" BC is marked the same, looks just like it except for the difference in the BC's and a smaller center hole. The fan clutch (non-Eaton) could look the same for both hi and lo-po applications, only the bolt circles tell them apart.
« Reply #10 on: November 04, 2017, 12:37:17 AM »
Gary you're fortunate that your car still retains the plastic cap on the left hand shock thread - originals seem to be made of unobtanium!
« Reply #11 on: November 04, 2017, 04:44:54 AM »
Yes, when I first found that on the left shock, I was upset that the right one was missing..  :)
Daytona Yellow 69 Z/28
« Reply #12 on: November 05, 2017, 01:30:38 AM »
I found one of the shock plastic caps when I cut the left side quarter panel off my new 68 Camaro project last week. It was laying down between the quarter & the trunk drop off.  :)
« Reply #13 on: November 05, 2017, 01:55:26 AM »
Nice find!
L78racer
« Reply #14 on: November 05, 2017, 02:47:03 AM »
i need one of those fan blades if someone has one for a reasonable price. mine blew apart at the pure stock drags. '68 L78. i attached a pic but don't know if it will show up.
