Author Topic: 68 L78  (Read 4767 times)
ccargo
68 L78
« on: February 02, 2007, 02:32:06 PM »
I'm converting my 68 L78 from manual steering to quick ratio power. I have the correct pump and pulley and already changed the box and pitman arm. I'm having trouble getting the bracket to clear the balancer. Did the L78 have a special power steering bracket?
67 O-1 O4A L35 Convertible, Indy Zone IPC
BlackoutSteve
Re: 68 L78
« Reply #1 on: February 04, 2007, 11:29:40 AM »
No.
The correct PS pump mounting bracket is GM#3863146 as per the 1968 AIM (N40-A6). The rear adjustment brace is #3876788.
This is for all 396 engines. The L78 or N40 chapter shows nothing of a different PS bracket for the 396/375.
Just checking that the crank pulley for your L78 is #3869978.
What is the correct diameter balancer for the L78? 6-1/4", 7-1/4" or 8"? What's yours?
I did buy a repro PS bracket set for my 69 BBC and the fit was horrible! I had to bend it stightly to get it to line up, and the nut for the through-bolt was welded on out of square. Even the supplied through-bolt was an ungraded bolt with a metric head. (That went straight in the bin!) How disgusting! >:(
If yours is a repro, maybe it was made by the same cheap'n'nasty off shore company that made mine!
« Last Edit: February 04, 2007, 11:32:57 AM by BlackoutSteve »
