Author Topic: "DZ" grease pencil mark  (Read 20777 times)
X33RS
« on: October 12, 2017, 01:56:33 PM »
I've looked at 2 very nice 69 Z/28's recently that had DZ written on the passenger side head.  Both Norwood cars.
Was this a common thing or another case of someone adding something that wasn't there originally?
Re: "DZ" grease pencil mark
« Reply #1 on: October 12, 2017, 06:30:28 PM »
If I see that on any car, my thought is “over-restored”.  Those are generally under the paint.
I would never do that on any car I own.
« Last Edit: October 13, 2017, 07:18:44 PM by bcmiller »
X33RS
« Reply #2 on: October 12, 2017, 09:38:21 PM »
So was this done at the plant originally?
I've seen original dual stripe marks on the cylinder heads so I know that was done off and on at Norwood.  I'm just curious about the "DZ" I've been seeing lately.
« Reply #3 on: October 12, 2017, 10:10:52 PM »
If I see that on any car, my thought is “over-restored”.  Might have been there a short time, but after several heat cycles “gone”.
I'll play devils advocate here......when restoring a car, isn't one goal to have it look as it did when it left the factory....marks included, even if they 'wore' off quickly?  ;)
« Reply #4 on: October 12, 2017, 10:51:29 PM »
I thought BillOHIO 's 69 Z had that mark on his cylinder heads . He purchased his car with fairly low milage, and could make it out  - I think
BillOhio
    • photobucket
« Reply #5 on: October 12, 2017, 11:19:23 PM »
Mine had the dual stripes on the drivers side.  It had some weird marks on the side of the block that looked like ok
I will see where the stripes pics are
1968 RS 327 4 speed
BillOhio
    • photobucket
« Reply #6 on: October 12, 2017, 11:27:12 PM »
The head is when it was still in the car. It was easier to see than what the picture shows. The side of the block, this was after it was hot tanked.
In either the how to Hotrod your small block Chevy or how to rebuild your small block Chevy, there's some pictures of blocks on the assembly line with the engine code written on the side of the block. Mine looked more like ok but I suppose it could have been DZ
1968 RS 327 4 speed
« Reply #7 on: October 13, 2017, 03:07:51 AM »
My tendency is to agree with Mr Miller on this point...  i would not do it to my car, and I suggest the ones you seen with this recently were 'recent restorations'..  by restorers who read 'more' into things than they should... :)
as John Z said....   'restoration graffiti'....      UGH!
Stingr69
« Reply #8 on: October 13, 2017, 12:50:01 PM »
The sides of the block grease pencil marks are certainly legit and they did last.  There were several other marks that I do not know the meaning of on blocks. I have seen marks on other untouched examples.  That is how the line knew what parts to put in there.
« Reply #9 on: October 13, 2017, 01:52:33 PM »
I think the 'point' is that any grease pencil marks were put on the block *before it was completed and painted*, and generally the marks would be gone before/by the painting step.  Of course, we have seen a few examples where the marks became obvious *thru old thin* paint many years after and those situations are neat because they help us understand how the engine plants did their jobs.
What disgusts me is the some 'restorers' read such things and decide that their *restorations* are more authentic if they put their bright splashes of color and marks all over the car AFTER the parts are restored (makes them lots more obvious doesn't it?).. :)    THAT is 'restoration graffiti'...
« Reply #10 on: October 13, 2017, 03:58:40 PM »
 Looking at the original posters comments about 'DZ', wasn't it a practice to hand write the motor prefix on the visible side of a head to make it easier for the person who had to retrieve the block from the rack? I'm sure we have all seen the pictures with motors and writing on the blocks and valve covers sitting on the train terminal loading docks. As I understood it, on racks of motors, there could be different prefix codes and unless one climbed onto the rack to look at the pad stamp the grease mark on the head made it easier to distinguish. I understand that marks on a bare block being assembled have had them painted over. I agree that some cars are way overdone with marks. I've seen a Chevelle at a show recently and it looked like someone shot at the engine compartment with a paintball gun.
    When you step back and look at the PBT, linkage paint dabs, the occasional surviving factory post-assembled inspection dabs (have them on my steering joint to shaft bolt), surviving marks on firewalls (I'm not referring to those under the blackout), marks written inside front end panels like extensions and valence, and the white 'X' on the washer fluid tops, there is already a lot of 'graffiti' when it left the factory.
« Reply #11 on: October 13, 2017, 05:19:11 PM »
In general, those markings would be for engine plant assembly purposes, buried under paint. Sometimes paint was thin or burned off a bit and then may have shown through.
I can’t say it never happened (marks on top of paint) as there are a few pics out there. Mostly seen on MO engines in 68. That might have been due to a different type of marker used or a slightly different engine paint mix or supplier, making it easier to show through. But it wasn’t the norm as far as I know.
Assembly line ID of a DZ should have been pretty easy. Think about it. Small block, aluminum intake, special valve covers.
Do what you want people. I just stated I would never do it.
« Last Edit: October 13, 2017, 06:54:02 PM by bcmiller »
« Reply #12 on: October 13, 2017, 06:23:22 PM »
The 10D norwood I restored a few years back... 302 on the side of the block upon tear down.
X33RS
« Reply #13 on: October 13, 2017, 06:46:41 PM »
Very cool James, first I've seen of that.  Neat to see the writing right side up with the block up side down.  Tells a story.
I have a couple of BBC's here that revealed grease pencil markings on the block after hot tanking.  I figured hot tanking for sure would take that off but it didn't.   I'm guessing this stuff stays somewhat preserved if you're looking for it.  Paint doesn't stick well to the grease markings so even though they are painted over, after a while they tend to bleed through it seems.
  I also have a 1966 HE code 327 here that has HE written on the side of the block in huge letters.
What Bill showed are the dual stripes I was talking about.  I've seen that before.  I always thought that was to help a line worker quickly identify a double hump head, but just a guess.  I've only seen engine designation stuff on the sides of blocks, similar to what James posted and similar to what I have here.  I haven't seen DZ written on the front of a cylinder head until most recently so I thought I'd ask the question here.  Thanks guys.
« Reply #14 on: October 13, 2017, 06:54:59 PM »
That’s there so they know what rotating assembly to install. Markings done before paint.
And I changed some of the wording in my first post above.
Right off hand, not sure on small blocks - but on 69 big blocks, there was an engine code sticker put on the valve cover for ID.
« Last Edit: October 13, 2017, 07:22:05 PM by bcmiller »
