Author Topic: M22  (Read 6126 times)
Tx-Z 302
M22
« on: September 14, 2017, 02:52:45 PM »
Can somebody explain the process of how a 68 camaro would get a m22 from the factory? I was under the impression All 68 Z cars received the m21?  I've run across 2 68 Z28's with supposedly factory M22's both are dated early to mid 68. One is march, the other is June?  Niether One has a partial vin ????
Chris W
Re: M22
« Reply #1 on: September 14, 2017, 03:06:51 PM »
For the 1968 Camaro, the M22 was optional on the L78, L89 and Z28. All you needed to do was check the box on the order form and fork out $295. 1277 customers did just that.
Tx-Z 302
Re: M22
« Reply #2 on: September 14, 2017, 04:57:23 PM »
Well that explains that it was an option thank you.  So why would they not stamp the vin like the m21?
Chris W
Re: M22
« Reply #3 on: September 14, 2017, 05:07:32 PM »
Quote
They would. However, the VIN may not be stamped in the "usual" place (on the side). We've seen a lot of Muncie transmissions stamped on top (see example below)
Re: M22
« Reply #4 on: September 14, 2017, 05:37:50 PM »
Especially Los Angeles built Camaros.  My car has the partial VIN stamped twice on the top of the transmission, as seen with a mirror with the trans in the car.
VINCE Z28
Re: M22
« Reply #5 on: September 14, 2017, 06:11:35 PM »
L. A.  continued it in 69.
Tx-Z 302
Re: M22
« Reply #6 on: September 15, 2017, 07:19:48 PM »
Tha is for the replies  and pics. So if you checked that box did the m22 come with the 403 bellhousing and 10 inch clutch and flywheel or the 11 inch set up?
Chris W
Re: M22
« Reply #7 on: September 15, 2017, 07:26:04 PM »
The Z28 came with the 10.5" clutch and the L78 and L89 came with the 11" clutch, no matter which Muncie transmission was ordered (M20, M21 or M22).
Hans L
Re: M22
« Reply #8 on: September 22, 2017, 05:39:56 PM »
Appears LA changed the VIN stamp location later in the '69 model year.  Mine was stamped on the side by the Trans ID stamp.
'69 Chevelle SS 396 4 Speed
'70 Camaro SS L78
Re: M22
« Reply #9 on: September 22, 2017, 07:43:40 PM »
My 10B (early) LA car has it in the same place as yours Hans. Kinda faint on the 9L portion, and then heavier on the partial vin.
