Author Topic: 68 Core Support - Standard vs RS..............  (Read 5421 times)
rod396
« on: September 11, 2017, 08:24:14 PM »
On a 68 RS, I do not have the original Core support, but found one from a 68 Standard. My question is, on the washer bottle mount, would the factory original core support on the RS NOT have the 3 triangular pattern holes pierced on the left side of the core support, as the RS mounts the bottle farther back on fender?
Does anybody have an original 68 RS on which they could confirm these holes pierced or not?
Thank you.
feastersss
Re: 68 Core Support - Standard vs RS..............
« Reply #1 on: September 13, 2017, 12:12:40 AM »
I'm looking at my 68 RS, and if I remember correctly from looking at a non RS the tank sets behind the left headlight, if that is the case, I do see 3 holes pierced that appear to be the same pattern as the mount for the bottle on my car, hope that helps!
'68 RS/SS BB L35 Convertible..., Born w/drive train, R1 paint,  red interior, 725 Deluxe interior, white power top
8N325767....Looking for POP
« Reply #2 on: September 13, 2017, 09:06:06 PM »
I just went out and looked at mine (1968 RS/SS) and yes, the holes are there. Mostly covered by the voltage regulator but there!
I would imagine the holes are in ALL supports since there was only one support used (P/N 3938695). If the Z22 used a different support, there would be something in the AIM or the P&A showing a different part number.
rod396
« Reply #3 on: September 13, 2017, 09:36:17 PM »
Thanks for your responses. Yes, I was questioning this solely on the fact that the holes were pierced, and not stamped.
68L30
« Reply #4 on: September 13, 2017, 10:32:48 PM »
Whats the build date of your 68? Late core supports carried the dimpled spots on top for the AC seal.
« Reply #5 on: September 14, 2017, 12:42:18 AM »
There's a notation in the AIM (note 2) but the note is impossible to read. The date is 7-13-67 and it appears to be something like "was 3927462", which I DID find in the November, 1967 P&A for the 1968 Camaro support. So it appears that sometime in 1968, the support went from 3927462 to 3938695. Perhaps this was when the dimples for the AC seal were added?
rod396
« Reply #6 on: September 14, 2017, 08:23:00 PM »
Build date 10/67
luv2sixty9
« Reply #7 on: October 19, 2017, 11:35:19 PM »
Also on 68 Rad Support the upper hole, which is used only on a non RS car for the horn is further away from the raise / bulged line. This is to accommodate for the special large washer used to mount same. A hard item sometimes to locate and seldom present on cars. Dave
1967 Z/28 Butternut Yellow
1969 Z/28 Rally Green
1969 RS Z/28 Lemans Blue
1969 RS Z/28 Olympic Gold
1969 RS SS Pace Car
2010 Aqua Blue 2SS RS
