My gearbox is leaking from the input shaft (under the rag joint) and might possibly be messed up internally. I've only put 390 miles on the car since getting it back last August and the power steering went out last weekend, only to work again the next day when I was moving it around the property.
The pump is new (I wish we'd have rebuilt my original) but I'm told that shaft breakage is not uncommon. I haven't pulled the belt to check.
I found a business that rebuilds gearboxes, powersteering.com. Also read good things about west texas offroad (as far as rebuilding gearboxes). My first priority will be taking out the gearbox, then checking the pump. Anyone have recommendations on repair sources?
