Author Topic: splash pan  (Read 5481 times)
pjbizjak
splash pan
« on: September 06, 2017, 10:25:08 PM »
Hello, did the 1968 z/28 302 have a oil splash shield?
Pete
x66 714
Re: splash pan
« Reply #1 on: September 06, 2017, 10:56:07 PM »
If you're talking about a windage tray, yes...Joe
pjbizjak
Re: splash pan
« Reply #2 on: September 06, 2017, 11:40:17 PM »
I'm talking about the shield that's attached to the main caps with special bolts.
Re: splash pan
« Reply #3 on: September 06, 2017, 11:49:05 PM »
That's the windage tray.
pjbizjak
Re: splash pan
« Reply #4 on: September 07, 2017, 02:53:36 PM »
OK thanks. The windage tray I have came from a 4 bolt 350 sbc and I'm using it on a two bolt 302 z/28. However the special bolts are two long (4bolt vs 2bolt main caps), Can these be cut down or are the correct bolts available?
Re: splash pan
« Reply #5 on: September 07, 2017, 04:15:52 PM »
The original 3872718 studs were discontinued LONG ago, but you might still be able to find them on ebay. I think you can get functional replacements from Milodon or ARP though.
x66 714
Re: splash pan
« Reply #6 on: September 07, 2017, 05:01:37 PM »
Anybody have the specs?...Joe
Re: splash pan
« Reply #7 on: September 07, 2017, 05:24:13 PM »
Quote
Approx 1.125" of 7/16-14 thread (3" long) on one side, with approx 1/2" of 3/8-16 thread (2" long) on the other side, with a total stud length of 5-1/4" (see attached)
x66 714
Re: splash pan
« Reply #8 on: September 07, 2017, 08:14:42 PM »
Thanks Ed. I found some of these in a box a month ago. We'll see if that's what they are when I get home...Joe
x66 714
Re: splash pan
« Reply #9 on: September 07, 2017, 11:05:18 PM »
Sorry no good news. There's 10 in that box & all of them are the longer ones....Joe
pjbizjak
Re: splash pan
« Reply #10 on: September 08, 2017, 12:14:54 AM »
thanks guys, the bolts I have must be the long ones, 3-5/16 on the long end and the same on the short end. The 5/16 is exactly the length that prevents me from using them. Do either of you have a problem with cutting them down? In the mean time I'll search the internet for the correct ones.
Pete
mls68z28
Re: splash pan
« Reply #11 on: September 08, 2017, 12:48:48 AM »
When I built my homemade 302,30 plus years ago I had to cut the bolts down and had no problem.
Mitch,1968 Z28 03C Norwood,03/18/68,Seneca Falls NY,Z/28 Emblems.Purchase 05/04/78
