Author Topic: Exhaust line for a small block: which one to buy ?  (Read 8561 times)
lemarin
« on: August 26, 2017, 03:17:29 AM »
I'm looking to replace the complete exhaust line from the manifolds to the tail pipes. My main objective is to stay the closest as possible from the factory look. I don't mind much about the sound....My car is an LM1 350, RS 1969 with dual exhaust
Which one would be the best to buy ? Aluminized, stainless ? 2" or 2.5" ?
I've found those one:
https://www.camarocentral.com/1969_Exhaust_System_Small_Block_Aluminized_2_p/fue-108.htm
or
http://www.rickscamaros.com/camaro-original-style-exhaust-system-kit-2-1969.html
or
http://www.heartbeatcitycamaro.com/store/product/13890/1969-Camaro-Exhaust-System-SB-302-307-327-350-High-Quality-With-2-1-4-Headpipes-Made-In-The-USA%21/
Thanks to all !
Jeep Grand Cherokee SRT 2017 brillant black
BMW M3 ZCP 2017 Yas Marina Blue
Chevrolet Camaro RS 1969 Daytona yellow
Tesla 3D 2018 AWD (ordered)
Re: Exhaust line for a small block: which one to buy ?
« Reply #1 on: August 26, 2017, 04:12:21 AM »
Just one man's opinion...
The 2" is more than sufficient for your LM1..
I prefer aluminized over stainless (for the sound), as stainless pipes/mufflers always sounds 'tinny' to me...
lemarin
« Reply #2 on: August 26, 2017, 05:06:15 PM »
thanks for the reply, I appreciated. I want it as much as possible close to the original, in shape and in size.....so 2" is the smallest I could find, so far.
MO
« Reply #3 on: August 27, 2017, 03:11:29 AM »
Google Gardner Exhaust.
lemarin
« Reply #4 on: August 27, 2017, 03:44:45 PM »
I searched Gardner Exhaust. Just one word: wow !
Anyone has experience with this company ?
I asked them a quotation.
MO
« Reply #5 on: August 28, 2017, 02:40:58 AM »
Yes. Costs a little more than aftermarket, but they are as close as you can get to original.
BillOhio
    • photobucket
« Reply #6 on: August 28, 2017, 12:51:51 PM »
Friend of mine got his at D&R and was happy with it. Had to rub it in that it was alot cheaper than my gardner
1968 RS 327 4 speed
jeff68
« Reply #7 on: August 29, 2017, 12:14:36 PM »
I have a Gardner deep tone exhaust (with concours show package) on my 68 convertible.  It fits beautifully, looks perfect, and sounds very nice.  As noted, not cheap.  The guys at Gardner were excellent to work with.
PS:
My only issue is regarding the sealant they supply for the exhaust joints.  The sealant that came with mine was an acid-cure clear silicone sealant.  This means that it reacts with moisture in the air and produces an acid when it cures.  IMO, not what you want in a $$$$$ exhaust system.  I used non-corrosive Permatex Ultra Grey at the slip joints instead.  They guys at Gardner say the original sealant was clear, but I'm OK with the grey as it isn't noticeable at all.
« Reply #8 on: August 29, 2017, 12:19:55 PM »
Jeff,
Is your exhaust from Gardners stainless steel or aluminized?? or ??
jeff68
« Reply #9 on: August 29, 2017, 01:12:55 PM »
It's aluminized steel.  I don't think Gardner does stainless systems.
Hint:  Wear gloves when installing the system, then wipe down with lacquer thinner after it's all in place.  This will eliminate those nasty little fingerprints.
« Reply #10 on: August 29, 2017, 03:20:45 PM »
  As mentioned earlier I would stick with 2". My car is for local shows and cruising so I made an exception for not having an exhaust like Gardners. I put Rick's BB factory style exhaust system on my '67 L35 convertible. It is made by D&A Old School Automotive in Oklahoma (Ricks doesn't disclose who makes them). D&A have a reputation for making excellent fitting exhaust pipes for stock and custom so I was happy to know they were making it.
  The 2 1/4" pipes are 14 gauge aluminized steel and the bends are smooth vs. the OE wrinkle style. I was very concerned about the convertible floor brace clearance and these pipes fit perfect and stay within the tunnel so as not to look like a pregnant guppy when viewed sideways. The mufflers are AP6555 for resonators and AP709114 for the rear. The resonator has a 2" ID but were swagged for the 2 1/4" in/out. I don't worry about that causing any loss of power because the loss will certainly be way upstream with stock exhaust manifolds, the first pipe bend, the flat spots to clear the transmission cross member and the floor brace. The main muffler is the same size as the original and has very good clearance between the differential cover and fuel tank.
 With a cam slightly hotter than a stock L35 (more lift and slightly longer exhaust duration) the sound is still a strong low rumble at idle and no 'peaky' resonating sounds at any RPM I put the engine through. As for clamps I used the guillotine style for the lower muffler and the OE style sold by Camaro Central that have a small 'bump' on the bottom, though not as accurate as Gardner.
  I'll post some pictures later if interested.
« Reply #11 on: August 29, 2017, 09:42:50 PM »
as I said earlier, I don't like the sound of stainless steel exhaust; the metal is thin and I think that's why it sounds 'tinny' to me.  I'm glad that Gardner is making aluminized systems now...
mlc48
« Reply #12 on: September 04, 2017, 12:45:26 PM »
my opinion is Gardner exhaust is the best and Eric is a great guy to work with.  Highly recommend them
lemarin
« Reply #13 on: September 04, 2017, 06:09:23 PM »
I'm sure Gardner is the best....but I have to be honest: my Camaro is only an RS, so doesn't worth as much as a Z or SS......and also it's very clean under, but not Showroom....
I believe that an aluminized 2" from any supplier (heartbeat, Rick's or Camaro Depot) should do a great job.....
I will not go stainless for sure.
MO
« Reply #14 on: September 05, 2017, 03:27:11 AM »
There are plenty of good aftermarket options out there; I'm sure you won't be disappointed. But that is not what your original objective was.
