Author Topic: 69 Camaro Rear Wheel Well Plugs  (Read 8497 times)
Edgemontvillage
« on: August 10, 2017, 03:30:06 PM »
I'm detailing the rear wheel wheel wells on my 1969 RS Z/28 restoration project ("Brooklyn Z") and was unable to locate disassembly photos of this area. The wwells have received color overspray and now need to be undercoated. I'm conversant with the undercoating process however need to confirm the location and type of plugs originally used in the three, 3/4" holes inside each rear wwell. Quarter panels are original to the car and I recall that my original plugs were a combination of Caplug BP 3/4" recessed style plugs similar to those used on the cowl (2 x 1/2") and on the firewall (single). The other type of plug used was a body plug style plug also found in other locations (floor pan, bottom of trunk drop offs). Below are photos of both types of plugs (web sourced photos). Below also are photos of Eddie M's Cortez X77 Sept 69 Norwood build (mine is a 2B Norwood build) which show only the body plug style plugs used in all 3 rear wwell hole locations. What style (and mix) of plugs were originally used in rear wheel wells?
Caplug BP recessed style plug (example only, ignore size)
Typical Body Plug style plug
Rear Wheel Well - Eddie M's Cortez Z
Re: 69 Camaro Rear Wheel Well Plugs
« Reply #1 on: August 10, 2017, 10:23:25 PM »
Lloyd not sure if it was your car being referenced, but Mike P's build thread touched on this area, and may be of help:
http://www.camaros.net/forums/133-build-projects/186787-69-grandma-copo-clone-resto-one-step-time-209.html#post3237817
I do recall that there was a difference between the style of plugs observed on LOS cars, will check my notes.
Edgemontvillage
« Reply #2 on: August 10, 2017, 11:11:42 PM »
Nice pick up Tim, "what is lost is found"! Thanks!
Edgemontvillage
« Reply #3 on: August 10, 2017, 11:34:00 PM »
As Tim's research uncovered (nice work Tim), deep in a TC build thread (Post # 3130...) were photos of my original rear wheel wells and plugs.  As shown, the 2 rear plugs are Caplug BP 3/4" recessed style and the single, forward position plug is a body plug style. Unlike Eddie's Cortez Z plugs which are all body plugs it has an embossed PN.
Brooklyn Z Wheel Well with original Caplug BP 3/4" recessed plugs (2) in rear position
Plug Removed showing body color
Original Plugs
« Reply #4 on: August 11, 2017, 11:33:45 PM »
I've seen both types used and others that used all the rubber type. And as Tim was thinking the LOS cars had the plugs put in after and NOR cars prior to undercoating. Good pics to post again!
Edgemontvillage
« Reply #5 on: August 13, 2017, 03:42:33 PM »
An original example; 1969 Camaro 307, 60K miles, never apart, Norwood car originally registered in CA, showing all body plug style wheel well plugs (per Eddie M.):
Edgemontvillage
« Reply #6 on: August 17, 2017, 02:55:23 PM »
By the lack of posts I take it most members don't have much interest in this subject!
Here is a very original 68 Z/28 survivor (Rich, "ALLZS"), I don't have the build details, showing a Caplug style wheel well plug:
JKZ27
« Reply #7 on: August 18, 2017, 01:15:08 AM »
My 12B Norwood 69 SS. Looks like the Caplug type. Hope this helps.
John
John
68 RS Ash/Ivy Gold 327EFI M20
« Reply #8 on: August 18, 2017, 01:27:13 AM »
1968 LOS 12D
Only shot I could find from Teardown, I however have a baggie marked rear wheel well plugs that has a combination of the two styles.
I was not sure "IF" your title was for 69 info (data) only, but then you posted a 68 so I figured I would add this photo.
X33RS
« Reply #9 on: August 18, 2017, 12:43:21 PM »
I'll throw a curve ball in the mix.  My 12D Norwood 69 is still original and unrestored in this area.  Driver side has cap plugs in the front and the single plug in the rear is a body plug. However on the passenger side all 3 plugs are original cap plugs.  No body plug in the rear on that side of the car.
« Last Edit: August 18, 2017, 01:56:22 PM by X33RS »
Edgemontvillage
« Reply #10 on: August 18, 2017, 02:24:54 PM »
1968 LOS 12D
Good observation Jim, as I wan't seeing many contributions of '69 examples I included a '68.
« Last Edit: August 18, 2017, 03:52:58 PM by Edgemontvillage »
Edgemontvillage
« Reply #11 on: August 18, 2017, 03:56:23 PM »
John
Thanks John, first example I've seen of the Caplug type plug used in addition to my 69. Thought it might be an outlier.
HawkX66
« Reply #12 on: August 19, 2017, 10:18:40 PM »
My 08D are like these Lloyd. I'd post a pic of it during dismantling, but flickr won't let me from my phone.
Dave
69 SS396 X66 L34 M21 BS
Z23 711 U17 Hugger Orange
Semper Fi!
