Author Topic: 12 bolt Camaro rear, casting date question  (Read 3045 times)
67jeffreyt
« on: July 23, 2017, 07:59:44 PM »
So I bought this 12 bolt rear cheap, and got home to check all numbers. Multi leaf spring mounts. Axle tube is code BL for a 68 3.07 open rear.  Ring and pinion are dated 67 correct 3.07 ratio.  But the carrier casting number looks like January of 67.  Is it normal to be cast that far in advance before being built? Or am I reading the cast date wrong? Would it be letter I- 28- 7, meaning September 28 1967?
« Last Edit: July 23, 2017, 08:26:15 PM by 67jeffreyt »
67 ss/rs camaro currently
68 prostreet Camaro 9.60 1/4 mile
68 Rallysport, first car high school
89 rs camaro convertible, made readers rides super Chevy
Re: 12 bolt Camaro rear, casting date question
« Reply #1 on: July 23, 2017, 08:23:42 PM »
It's I 26 7 (I as in Igloo) which would be September 26th, 1967. For "cast" parts, the letter I was used for September. (The letter I wasn't used for "stamped" parts.)
67jeffreyt
« Reply #2 on: July 23, 2017, 08:59:28 PM »
Ok thank you, I was thinking it was a one not an i. Guy threw in leaf springs and traction bars and complete brakes.  It came with a project 55 Chevy and he was installing a Ford 9 inch.
