Author Topic: gauge cluster lighting  (Read 4980 times)
BobH11
« on: July 17, 2017, 10:35:23 AM »
could someone tell me what this is. It seems plug in behind the oil pressure gauge.
KevinW
Re: gauge cluster lighting
« Reply #1 on: July 17, 2017, 11:10:23 AM »
Bob, looks like the low fuel warning module.  Kevin
BobH11
« Reply #2 on: July 17, 2017, 11:23:54 AM »
That's it ...Thanks Kevin
« Reply #3 on: July 17, 2017, 02:53:31 PM »
I think it plugs into that empty hole between the light bulbs, but no bulb goes in it.
« Reply #4 on: July 17, 2017, 09:59:13 PM »
Correct. They always fall out of the hole at some point, apparently. Mine was loose in the bottom of th egauge pack when I took them out of the console - it's not a very tight fit. Understand this module was used in other applications that used a bulb in this socket ?
