Author Topic: 1968 Z/28 distributors 1111266 to 1111467  (Read 17417 times)
« on: July 15, 2017, 11:38:48 PM »
1967 Z/28’s had 1111266 distributors and apparently large batches were made as many early 68 Z/28’s have them including at least three CRG members (Randy, Paul, and myself). This is an effort to help establish how long into the 68 model year were 266’s used and when did 467’s start. According to a GM memo in Jerry’s book 266’s were to be exhausted before 467’s went into use. Did it happen? When did the 467 start to show up? Since the distributor was put in at the Flint engine plant please give the assembly date of your engine, 266 or 467 and date code of distributor. Information from http://www.camaros.org/forum/index.php?topic=1539.0;all and here http://www.camaros.org/forum/index.php?topic=7371.msg48710#msg48710
A few I have:
11/21/67- Jerry –has 266 dated 7G20
??/??/67- Jim- (169Indy)has 266 dated 7G20 (CE block NCRS report car built 12/26/67)
12/21/67- Chick –has 266 dated 7A25 (NOR 01B)
12/21/67 Randy (Dutch) has 266 dated 7A25 (NOR 02C)
??/??/?? Paul (68RSZ28) has 266 dated 7A25 (LOS 02C-sent Paul PM for eng. build date)
05/23/68- Danny’s had 467 dated 8E03 (NOR 05E)
Tx-Z 302
Re: 1968 Z/28 distributors 1111266 to 1111467
« Reply #1 on: July 17, 2017, 08:28:39 PM »
Mine is nor 07B.    467.   8f4
Chris W
« Reply #2 on: July 19, 2017, 08:14:26 PM »
Great, but can you give when your engine was built if available. Reason being that is when distributor was put in. If not its still good information to have so thanks.
Tx-Z 302
« Reply #3 on: July 19, 2017, 11:25:26 PM »
I really really wish I could. I have an original MO  block with a April date ,  but its not original to the car.
Chris W
67rs/ss350 68z/28
« Reply #4 on: July 20, 2017, 12:12:39 PM »
Been a little busy with other things going on. Motor built If I remember correctly April 15th, but sorry didn't have original distributor in it. I had original 467 distributors with dates 8A5 8A10 and now I have 8B8 which is closer to my 04D build date. Now it looks like I guess all those dates would be OK for my car??
« Reply #5 on: July 20, 2017, 06:48:53 PM »
Yep, as next build of 467's was 8D23 from what info I have.
??/??/??- TX-Z 302 has 467 dated 8F4 (NOR 07B)
dutch
« Reply #6 on: July 27, 2017, 04:28:26 AM »
Chick - on the Yenko Supercar registry site you may want to check out a thread that Charlie Lillard started (68 Dana Z2/8) and go down to post #9 where he describes the distributor - you'll certainly love his comment fpr your '266 quest!
Randy
« Reply #7 on: July 27, 2017, 06:40:55 PM »
Nope that's a later date with that car. Unless I missed something.
« Reply #8 on: July 27, 2017, 11:42:33 PM »
Charlies - 12D LOS Dana special paint car has a 7G20 266  ENGINE BUILD V1207MO
luv2sixty9
« Reply #9 on: July 28, 2017, 08:53:29 PM »
Chick,
My 06A info: V0605MO, Dist 467 8E17
1967 Z/28 Butternut Yellow
1969 Z/28 Rally Green
1969 RS Z/28 Lemans Blue
1969 RS Z/28 Olympic Gold
1969 RS SS Pace Car
2010 Aqua Blue 2SS RS
jcihos
« Reply #10 on: August 15, 2017, 03:25:15 PM »
05C build Dist 467 8E3
« Reply #11 on: August 21, 2017, 09:59:58 PM »
Thank you! Can you add when your engine was built since that is when distributor was added?
jcihos
« Reply #12 on: August 29, 2017, 05:11:13 PM »
Sorry I cannot since it is not the original engine in the car.
Paul68RS/Z28
« Reply #13 on: October 15, 2017, 05:02:32 PM »
Chick, mine is 4/15/68 - 467 8A3 (NOR 4D)
dutch
« Reply #14 on: October 16, 2017, 01:44:07 AM »
Chick - Has there ever been any consensus achieved in  this matter - or is it still on-going?
Randy
