Welcome,
Guest
. Please
login
or
register
Did you miss your
activation email
1 Hour
1 Day
1 Week
1 Month
Forever
Home
Help
Search
Login
Garage Talk
TEMPERATURE GAUGE WONT WORK!!
« previous
next »
Print
Pages: [
1
Author
Topic: TEMPERATURE GAUGE WONT WORK!! (Read 5958 times)
feastersss
Member
on:
July 08, 2017, 08:39:44 PM »
I've completed a full restoration on my '68 BB with Console gauges and my temp gauge won't even move off of the cold mark, this is my first time ever dealing with a temp gauge, so I'm not sure where to start! Can anyone give me some pointers on where to start!
Tweet
Logged
'68 RS/SS BB L35 Convertible..., Born w/drive train, R1 paint, red interior, 725 Deluxe interior, white power top
8N325767....Looking for POP
Spooky
Member
Re: TEMPERATURE GAUGE WONT WORK!!
Reply #1 on:
July 08, 2017, 09:11:29 PM »
Did you wrap Teflon tape around the sender? That blocks the ground path from the sender. It was the first thing I would check. Also check the grounds to the dash. Seems like a very common issue.
Scott
Logged
feastersss
Member
Reply #2 on:
July 08, 2017, 09:21:48 PM »
No, I did apply a very, very small amount of liquid teflon, I haven't checked the ground at the gauge yet, to check it, does the entire top half of the console have to come out, or can I just pull the gauges out of the console?
Scott
Logged
ssl78
Member
Reply #3 on:
July 09, 2017, 03:24:01 AM »
Did you pull the wire off the sending unit and ground it to see if gauge goes to full?
Logged
feastersss
Member
Reply #4 on:
July 09, 2017, 10:50:37 AM »
No, but I'll try that...Thanks.
Logged
feastersss
Member
Reply #5 on:
July 09, 2017, 01:56:37 PM »
I did connect a ground to the wire that connects the temp sender and it didn't go to hot, so I removed the face plate from the gauges and moved the needle all the way over to hot, turned the key on and it immediately went back all the way over to cold!
Logged
Hero Member
Reply #6 on:
July 09, 2017, 05:42:13 PM »
Do a search. This has been covered multiple times. Start with
THIS THREAD
and the replies by Mark..
Logged
feastersss
Member
Reply #7 on:
July 09, 2017, 11:50:08 PM »
Thanks for all the help, I got it figured out!
Logged
Print
Pages: [
1
« previous
next »
Garage Talk
