1. Post a link to the fan. You have to be VERY careful. VERIFY it's the 3.25" and not the 3" spacing.
2. Tank codes were OD and IH, but the radiator APPLICATION code was UH (P/N 3010178), which was a 3 row radiator, also used on LF7's with A/C or V01 (Heavy duty radiator).
(Additional information on the fan and radiator
HERE.)
3. Again, post a link to the ad. The 4053 carb didn't have the vent. (Edit: If
THIS is the carb, someone's replaced the 4053 primary bowl with a 4346 bowl, which is incorrect. Also VERIFY it has the correct 5583 primary and 4519 secondary metering blocks) More info on Holley carbs
HERE.
