Author Topic: GM Ti ( TIU 3921048 - 1st design ) Amplifier Mounting Plate 3916730  (Read 5973 times)
big iron
Looking for measurements for 3916730 mounting plate. I have mounting plate 3954206, but because the hood catch support brace  was redesigned for 69, I need 3916730 mounting for my 67 build.
Bob
blackss69
Re: GM Ti ( TIU 3921048 - 1st design ) Amplifier Mounting Plate 3916730
« Reply #1 on: July 01, 2017, 11:58:42 AM »
I have one of those plates and will trace it for you (along with dimensions).  I need the same on the 3954206 plate.  Will you trace it along with dimensions for me?
blackss69
blackss69
« Reply #2 on: July 01, 2017, 08:29:33 PM »
I sent the message too soon.   The plate is not in the box it is supposed to be.  I'll continue to look but for now sorry I can't find it.
blackss69
« Reply #3 on: July 29, 2017, 06:43:58 PM »
Big Iron or anyone else.  I found the mounting plate for the HD Parts Transistor Ignition for 1967 and 1968 z28 Camaros.  I can trace this if anyone would like.  I need a tracing and dimensions for the mounting plate for a 1969 ZL1 Camaro that uses a similiar mounting plate.
big iron
I know old topic.
Does anyone have information showing that 3916730 is the correct part number and 3916739 is not. The P&A oct 1968, P&A 30A 1969 rev.7-1-69 and P&A rev. 10-1-69 all show 3916739 as part number for early plate. Why and who made the decision that 3916730 is a typo? To do that there should be documentation.
Bob
Needed one for our ZL-1 project many years ago. Bought a block from Lamar Walden and he offered to send an NOS part to copy. A true Southern Gentleman.
big iron
 3954206 is a 1969 only production part and will not fit the 67-68 vertical grill brace. 3916739 gr.2.383 (3916730 ) is an OTC part ( not production part) and will only fit the 67-68 vertical brace.
Bob
