Author Topic: Introducing the "GILMORE" 1968 Z28  (Read 238974 times)
Re: Introducing the "GILMORE" 1968 Z28
« Reply #135 on: April 06, 2022, 03:51:58 AM »
Thanks Guys, I appreciate the feedback.
I like to supply "credit" (i.e. acknowledgement)  for the Vendors but forgot that Joe Passed on and left that detail out of the post.
No Judging in this cars future (No events in the PNW), unless I can convince a few friends to fill a Reliable truck eastward to MCACN someday.
Chick PM me your thoughts
« Reply #136 on: April 06, 2022, 04:12:08 AM »
862 white plastic Horn relay, Had a spare leftover from the John Pirkle Days.
Quanta Tank replacement, plated orig dated clamp (4th Qtr 1967), repop hose, added anti squeek tar paper (ECS-vendor) and top-spacer (Mcmaster-Carr) & tapes (3M) and foam on the line. (*Orig tank scrapped by previous owner)
« Reply #137 on: April 06, 2022, 04:13:38 AM »
More tank.
I have noticed the SPECTRA-QUANTA (Canadian) Tanks are very nice, but they do develop a white "Tarnish" over time and it seems they ship with a protective film.
« Reply #138 on: April 09, 2022, 02:23:41 AM »
Pm sent Jim.... Again looking good....
« Reply #139 on: July 21, 2022, 03:00:38 AM »
Dated 1968 Camaro UN Walker Square mast "8 A" 32.5" Jack assembly source and fluffed, I think I need to strip and phosphate the commercial (AMK) replacement J hook.
Dan found a great paint avail that beats a Vintage Krylon Dove gray
SEYMOUR OF SYCAMORE
16 Fluid oz. Can Gloss Dove Grey Hi Tech Enamel
Mfr #: 16-112
« Reply #140 on: April 15, 2023, 05:20:51 AM »
 :)I Found the Used Car Ad for the Car.
NEWSPAPERS.COM
The Missoulian
17 Jan 1969, Fri · Page 22
« Reply #141 on: April 15, 2023, 12:46:48 PM »
Nice find.
« Reply #142 on: April 17, 2023, 02:52:07 AM »
I am also Digging to research further used sales of the Car locally in my Town in or around 1976 when the Gilmores traded in a VW as trade.
Car was Sold New in Missoula via T&W Chev. I did reach out to "Karl Tyler Chev' now Missoula Chev with little results.
This was a Fantastic find very easy using NEWSPAPERS.COM
JIM
« Reply #143 on: September 29, 2023, 05:57:12 PM »
Steering Column Rebuild Started.
« Reply #144 on: September 29, 2023, 06:08:56 PM »
Seam Sealer Applied using Lord Fusor Air application gun that Both sprays and extrudes (Beading) with SEM special TIP to achieve ripple effects.
Nice gun used on other projects also since this is not a daily activity for us. Heck of a clean up on the Gun and with practice you could get better results. This "TOOL" is nicer than a 7 dollar caulking gun by leaps and bounds & will have other uses.
rocco376
« Reply #145 on: September 29, 2023, 07:05:08 PM »
Great job.
« Reply #146 on: October 10, 2023, 02:07:12 AM »
Made progress on the Column, Thanks to Darrel for the tip on the Bearing and help discussing the Adjusters that are set (staked via Heat set) at Saginaw and are not really serviceable at rebuild. (* I trimmed mine on a lathe to increase endplay to allow for proper stick out distance to get the "C" clip installed.) A Neat Video on YouTube was helpful also.
Final Wheel, Used vintage  Walnut  to be installed at final assy of the interior
« Reply #147 on: October 13, 2023, 04:05:07 AM »
Interior Tub & Seam sealer painted out with Semi-Flat
« Reply #148 on: October 13, 2023, 01:59:03 PM »
Nice work Jim.  Glad you got the column back together.  Column and floors look great.  Keep it up!
« Reply #149 on: October 17, 2023, 06:57:18 PM »
Step by step Jim.... As Darrell stated, “nice work”
