Author Topic: dash lights  (Read 2701 times)
pterrell
dash lights
« on: June 29, 2017, 03:26:57 AM »
 New to forum, need help on my 67. I have lost power to dash lights. Checked fuse and No power to the fuse box. Where to I go from here?
Re: dash lights
« Reply #1 on: June 29, 2017, 02:13:39 PM »
I never had that problem on my 68 so I don't have a particular answer, but if you have a 67 AIM there is a wiring diagram in it and you can trace that circuit.  If you don't have one, there are downloadable ones on here. https://www.dropbox.com/s/pdmkny6ra24n4l4/1967%20CAMARO%20FACTORY%20ASSEMBLY%20MANUAL.pdf?dl=0
Re: dash lights
« Reply #2 on: June 29, 2017, 07:53:16 PM »
The dash cluster is grounded to the body via a wire loop that has to engage the top center screw. It is easy to install the screw and miss the loop.
It is shown [poorly] in section 12 page B3 of the '67 Camaro assembly manual.
