Author Topic: 69 Camaro Clutch Cross Shaft  (Read 6139 times)
jdv69z
  • 69 RS Z/28 52E
« on: May 24, 2017, 06:59:59 PM »
Ok, so I need to remove the clutch cross shaft to re-work my brake lines. Anyone have any tricks for re-installing it as there is a stud which has to slip into a fork mounted to the sub frame. The problem is reaching between the inner fender and the frame to re-install the stud into the fork, as it very close to the inner fender and getting my hand and/or wrench in there is tight. I'm working from inside the front wheel well with the tire removed.
Jimmy V.
HawkX66
Re: 69 Camaro Clutch Cross Shaft
« Reply #1 on: May 24, 2017, 07:42:22 PM »
Would it be easier to remove the subframe mount, mount the shaft, then re-mount it to the subframe? I can't remember it being very hard to get to.
Dave
69 SS396 X66 L34 M21 BS
Z23 711 U17 Hugger Orange
Semper Fi!
jdv69z
  • 69 RS Z/28 52E
« Reply #2 on: May 24, 2017, 08:29:23 PM »
 There are 3 bolts on the sub frame mount/bracket. The top one will not come out unless the inner fender is moved or bent. But I can move the bracket around with 2 of the bolts removed, and maybe that makes it easier. I'm going to find out, HaHa!
Jimmy V.
Stingr69
« Reply #3 on: May 25, 2017, 01:54:29 PM »
Its tight.  I do not recall much pain but I like to use the ratcheting box wrench.
« Reply #4 on: May 27, 2017, 04:11:33 AM »
I have unscrewed the ball off the block and taken it off that way.
