Author Topic: 1967 body tag vs vin tag  (Read 21411 times)
Re: 1967 body tag vs vin tag
« Reply #15 on: May 21, 2017, 09:19:10 PM »
Thank you sir.
« Reply #16 on: May 21, 2017, 11:37:05 PM »
And I will verify that. Kurt pointed me to one not long before I found the 67 base 327 car for my son.
Mi67RS
« Reply #17 on: May 22, 2017, 12:30:37 AM »
Thanks all. I wasn't sure about the body number and I didn't want to take the time to ask. I wanted to get you guys the photo of the tag so better safe than sorry. Is the column shift a rare option. seeing how the drive line is missing and the possibility of getting the original items back is probably zero, would I be safe to just restore the car they way i want. I have a early 1970 high nickle 010 350 out of a Chevy station wagon, a muncie 4 speed with a hurts competition shifter. I have a Saginaw trans but not sure where it can from. Actually i have a few manual trans another that I have is a super t10 with the fine spline, which would be the better choice.
« Reply #18 on: May 22, 2017, 01:29:18 AM »
Go with the Muncie.
Column shift was standard.
« Reply #19 on: May 22, 2017, 02:12:38 AM »
Quote
The "high nickle" block is an old wives tale that's been propagated over and over through the years. No one knows how or where it began, but the "010" and "020" cast into that front bulkhead identifies the common core pattern used for two different blocks, not any metallurgy. More info HERE (read the replies from JohnZ and Bergy).
And I agree with Bryon. Go with the Muncie.
Mi67RS
« Reply #20 on: May 23, 2017, 03:18:24 PM »
Quote
Thank you Ed, guess I'm guilty of drinking the koolaid. Another wives tail I've heard about the "010" blocks is they were all four bolt main
« Reply #21 on: May 23, 2017, 03:52:10 PM »
Quote
Don't feel bad. A lot of people STILL believe it!
Quote
Yep, another mistake most people make. Only the high HP engines got the 4 bolts mains. The lower HP engines were 2 bolt. However, most truck applications, even the lower HP engines, got 4 bolt.
Mi67RS
« Reply #22 on: May 24, 2017, 05:51:32 PM »
Would this car have had a front stripe and if so what design and color
« Reply #23 on: May 24, 2017, 06:29:33 PM »
Probably didn't have a stripe.
See this link.
http://www.camaros.org/exterior.shtml#stripes
« Last Edit: May 24, 2017, 07:35:15 PM by bcmiller »
Mi67RS
« Reply #24 on: May 26, 2017, 01:04:53 AM »
The link tell me this
"Pinstriping was not available as an RPO, but was included with Style Trim or Rally Sport."
My car is a true RS so would I read this correct that it would have the D91 stripe as part of the RS option?
« Reply #25 on: May 26, 2017, 02:05:07 AM »
Quote
No, it would have come with the D96 pin stripe.
D91 (the bumble bee stripe) was part of the SS package in early 1967 and not available as a stand alone option for other cars (except the Z28) until March, 1967. Your car was built the 2nd week of November, 1966, before D91 was an available stand alone option, so no, it wouldn't have come with it.
jdv69z
  • 69 RS Z/28 52E
« Reply #26 on: May 26, 2017, 02:57:43 PM »
Quote
Quote
Yes, wasn't the 2 or 4 bolt done on the engine assembly line? Or just before? There were set ups to drill either as required by the orders being run.
Jimmy V.
« Reply #27 on: May 26, 2017, 08:00:17 PM »
Quote
John or Bergy can elaborate, but yes, all the final machining was done after the block was received from Flint/Saginaw (or Tonawanda) and just before the block was assembled. Exactly "where" in the plant I don't know, but John's SMALL-BLOCK ASSEMBLY OVERVIEW article has a lot of great information in it.
Niblet
« Reply #28 on: January 22, 2019, 11:09:43 PM »
Great topic
1967 SS 350 coupe one owner (well now 2)
1967 RS Vert
Quick L30
  • Gordon
« Reply #29 on: March 16, 2019, 12:54:13 AM »
My L30/M20 RS is an Los 11B car as well. Just dropping in to say hi!
1967 RS L30 - M20
11B
R-R
Original 327 & K19 intact
