Author Topic: trunk mat cuts  (Read 15662 times)
69z27z87
  • The garage - my happy place
trunk mat cuts
« on: May 07, 2017, 01:38:12 AM »
Just finishing up my restoration and trying to put the new trunk mat in....original one long gone...I have not been able to find anything to tell me what cutouts i should make....One for the spare tire tie down?. One for the jack brace in the back?
I am most confused about how it was cut around the support for the trunk latch...was it cut to lay in front or did it also wrap around the back? Were there cutouts for the top of the shocks?
Anyone have an original mat they can post a pic of?   Most original cars do not have pics looking toward the latch... just inward toward the front of the car...
Also, what is the best tool to cut the heavy rubber with? I think using a razor could go bad in a hurry......
1969 SS396 - L35, Z87 Daytona Yellow, Yellow Houndstooth, Black Vinyl top
1992 Z28 - LB9 Purple Haze, T-5WC, grey leather interior
abiddle
Re: trunk mat cuts
« Reply #1 on: May 07, 2017, 12:35:43 PM »
Attached a picture of an NOS mat. I've sold his one and I have a used original which is exactly the same size and shape. The only difference I could see between the NOS and used original is cutting for the tire hook, they are definitely the same around the latch support.
Let me know if you need other pics, I'm no sure this answered your question.
69z27z87
Re: trunk mat cuts
« Reply #2 on: May 07, 2017, 02:39:12 PM »
Thanks..!!!.that helps a lot....!
It looks like it is cut in front of the latch support only and does not go around it like a 67-68.
Also, it looks like it does not go up on the wheel wells or over the top of the shocks. It also doesn't look like it goes over the "bumps" in the back of the trunk....
Do you have a shot of an original one in the trunk so I can see exactly where it lies?
Re: trunk mat cuts
« Reply #3 on: May 07, 2017, 03:33:01 PM »
Attached is a photo of my original (laying out on the floor, not in my trunk), but you can see the cutouts from the factory...
Re: trunk mat cuts
« Reply #4 on: May 07, 2017, 09:23:47 PM »
interesting differences between assembly line and NOS, thanks Gary, and Abide
Re: trunk mat cuts
« Reply #5 on: May 07, 2017, 10:17:54 PM »
What is the cut slot on the left side?  Any markings on the back side?
abiddle
Re: trunk mat cuts
« Reply #6 on: May 08, 2017, 03:00:30 PM »
Do these help you? Are you trying to cut a reproduction mat to fit like an original? I haven't found a decent repro.
Andy
abiddle
Re: trunk mat cuts
« Reply #7 on: May 08, 2017, 03:01:48 PM »
Please email if you need specific pics.
69z27z87
Re: trunk mat cuts
« Reply #8 on: May 08, 2017, 04:32:16 PM »
Yes, I am trying to cut my repro to properly fit the trunk the way the originals did.... those pics help a lot.... especially around the back.....
Now to figure out how to cut that thick mat without putting a razor through my hand (again).
Re: trunk mat cuts
« Reply #9 on: May 08, 2017, 06:38:12 PM »
There were originally 12 trunk mats used in the first generation Camaro!
7663177 - 1967 Coupe without N65
7728644 - 1967 Coupe with N65
7689199 - 1967 Convertible without N65
7728646 - 1967 Convertible with N65
7779677 - 1968 Coupe without N65
7779681 - 1968 Coupe with N65
7779679 - 1968 Convertible without N65
7779683 - 1968 Convertible with N65
8738793 - 1969 Coupe without N65
8738795 - 1969 Coupe with N65
8738794 - 1969 Convertible without N65
8738796 - 1969 Convertible with N65
Each had its own configuration for cut-outs, depth, overhang, etc... ALL of them had been discontinued by the early 1970's but I can remember walking into my Chevrolet dealer in early 1981 and they still had ONE on the books under a different part number. It was a "catch all" for the Camaro and Nova. It fit, but you had to hack the he!! out of it!!
Re: trunk mat cuts
« Reply #10 on: May 08, 2017, 06:50:38 PM »
Seems like you could lay an original on top of a reproduction, use a marker, outline it. And then use some wood base (1/2 x 3) lay it on the lines and score it with a razor blade a couple of times with some plywood underneath.
Couldn't be much harder than putting torchdown on roofs, where we cut it to go around sky lights and AC units.
Daytona Yellow 69 Z/28
Re: trunk mat cuts
« Reply #11 on: May 09, 2017, 12:39:27 AM »
Here a couple pics I had on my computer of the mat from my 08C Z/28.
Re: trunk mat cuts
« Reply #12 on: May 09, 2017, 03:43:55 AM »
I purchased a reproduction a few years ago, but when it arrived..  it was *nothing* like the original (not the material, the thickness, nothing!).. so I returned it..
Re: trunk mat cuts
« Reply #13 on: May 09, 2017, 04:03:32 AM »
what is the hole in the left side of your original mat for Gary?
Also: Andy it looks like you are running a rubber sleeve around your jack and tire iron, I thought only Pontiacs had the rubber sleeve?
Re: trunk mat cuts
« Reply #14 on: May 09, 2017, 11:48:57 AM »
