Author Topic: Paint Compatibility  (Read 6772 times)
abozny
  • 1967 SS 350 4-Speed
Paint Compatibility
« on: May 02, 2017, 10:48:46 AM »
Hello, I have an all original 67 Camaro. The car was repainted over the original paint with a Lacquer paint. This paint started to lift off and now the paint does not look that good. Underneath I imagine is the original 1967 paint sanded down and painted over, but I do not know.
My question is, is it necessary to completely strip the paint to the metal if the original 1967 paint is there`? Or can the car be sanded down to the original primer and painted over with today´s modern paints?
If some paints would work better than others with the original primer, which paints would those be?
Thanks and Regards,
Allen
elcamino72
    • More Information on Camaro Fraud
Re: Paint Compatibility
« Reply #1 on: May 02, 2017, 01:21:32 PM »
You will want to check with your paint jobber for their particular paint preparation requirements for their products but generally speaking you will need to apply a sealer over the lacquer.
« Reply #2 on: May 02, 2017, 01:40:50 PM »
When doing a complete such as yours, I strip all that old lacquer off and start from bare metal. Unless you are building a beater/driver and do not care how long the job will last and have money to waste.
vtfb68
« Reply #3 on: May 02, 2017, 02:37:40 PM »
Allen,
 I have used a pressure steam cleaner to remove a repaint from a car. The poor repaint was also flaking off, but the clearly poor prep allowed the water to lift the paint off.
   It was free and took about an hour.
        VT
68 08E LA RS Y2 749 L30 M35
« Reply #4 on: May 02, 2017, 02:42:52 PM »
X2! Believe 99 out of 100 good shops will tell you the same thing.
« Reply #5 on: May 02, 2017, 03:10:02 PM »
 When dealing with paint that can cost well over $400/gallon (depending on color) and costly 2K primers you definitely don't want to reuse the old lacquer base.
abozny
« Reply #6 on: May 03, 2017, 03:08:54 PM »
Thanks for all the replies. The paint on my car is lifting, it is an acrylic and has no lead like the original paint. I am selling the car and want to tell the next owner that he will have to have the paint stripped basically to the metal and re-painted.
I wonder if anyone will even be interested in buying it! I live in Germany and was quoted 10,000 for a new paint job after stripping it down.
« Reply #7 on: May 03, 2017, 03:48:38 PM »
Post some pictures of it! (please)
 I have a 5th gen contact over there, and he loves buying old cars, especially F bodies.
As for the paint, it all depends on what kind of paint job you want.  Sky is the limit on what you can pay for a paint job, but if the car is to be a driver than you don't need the perfect sheen on the door openings and all the detail work of a show car finish.
 I agree with the above comments though, you definitely want it prepped correctly, no matter what quality of paint you go back with.
abozny
« Reply #8 on: May 10, 2017, 01:12:15 PM »
My pics are too big in size, can I somehow email you the pictures?
Thanks!
