Can anyone decode this date for me? It's on the base plate of a 69 Rochester qjet 7029215.
I've seen a few (VERY few) other carbs stamped like that (see the 27G7 stamp below), but I don't think they're date codes. At least nothing that would make sense. Yours appears to be stamped 35C2 is that correct? Or is it 35G2? Either way, if it IS a date code, the format isn't something in the "normal" GM formatting structure.
The closest I could find is this paragraph. If you can decipher it, you're a better man than me which is why I'm asking for help.
Basically that paragraph states that there are two different formats used in 1969 and two difference locations. (Another if yours really is a date stamp):
A letter/number format stamped on the body (see the L9 - December, 1969 - stamp below), a 4 digit Julian date stamped on the body (see the 0953 - 95th day of 1973, a service replacement from 1973 - stamp below), and a 4 digit Julian date stamped on the driver side of the base plate toward the rear (see the 2068 - 206th day of 1968 -
stamp below).
Thanks a lot Ed. I think you nailed it. The number I showed "might" be a date code, but not the one generally used for the carb. I found a few more pics that helped put the pieces together. The number I posted is 35 G 2. The 35th week is the 4th week of August which is also "G." 2 is probably 2nd shift. This is just a guess on my part for what the 35 G 2 is.
This first pic shows the later QJet with the date just under the carb # on the body. If you look at the base of the hand model's thumb in the pic, you can see a code like the first pic I posted.
The second pic shows the date code on the early QJets for 69 apparently. This example is of an original 7029215. It doesn't look like there is that other code near the mounting hole though.
The third pic is the same carb and it shows the carb number without the date near it.
The fourth and final pic is of a 7029201 carb I have dated 3458. It kind of punches a hole in what I've been seeing about the early/late locations and time frames though. It's Dec 11, 68 and the date is on the carb body. There must be some exceptions.
![](https://c1.staticflickr.com/3/2921/33995432325_c98032211f.jpg)
![](https://c1.staticflickr.com/3/2821/33182727943_dcde6139c0.jpg)
![](https://c1.staticflickr.com/3/2858/33152064194_26d0783971.jpg)
![](https://c1.staticflickr.com/6/5552/30382730914_dabce50b54.jpg)
