Hi Randy, I have listed this several times but print this off and place with your AIM.
1968 CAMARO FACTORY ASSEMBLY INSTUCTION MANUAL “AIM”
TABLE OF CONTENTS
UPC 0 - General Information
UPC 1 - Body and interior/exterior trim and hardware
UPC 2 - Frame
UPC 3 - Front suspension
UPC 4 - Rear suspension & prop shaft
UPC 5 - Brakes
UPC 6 - Engine
UPC 7 - Transmission & clutch
UPC 8 - Fuel & exhaust
UPC 9 - Steering
UPC 10 - Wheels & tires
UPC 11/13 - Front sheet metal, radiator & grille
UPC 12 - Electrical
UPC 14 - Bumpers & miscellaneous
396 Engine Related- Pages 272-290 & 298-303
4-Speed Trans Back-up Switch- Page 323
4-Speed Trans Shifter Adjustment- Page 321
4-Speed Trans Shifter Assy. to Trans. & Cross-Member-Page 320
4-Speed Trans Shifter Rods & Hardware-Page 318
4-Speed Trans Shifter Rods & Hardware Big Block-Page 319
4-Speed Trans Shifter Stabilizer Shafts (3 of them)-Page 320
Accelerator Pedal & Parts-Page 103
Accelerator to Carb-Page 105
Accelerator to Carb Linkage & Hardware Z/28-Page 441
Air Cleaner to Carb & Valve Covers Z28-Page 443
Alternator Brackets Z/28-Page 441
Alternator Mounting-Page 79
Ash Tray-Page 43
Axle U-bolts-Page 243
Battery & Battery Cables-Page 151
Battery-Heavy Duty-Page 381
Battery Junction Block (above battery tray)-Page 155
Battery Tray-Page 149
Brake Line & Emergency Brake Brackets-Page 243
Brake Line-Front-Page 72
Brake Line-Rear-Page 73
Brake Pedal-Page 71 & Brake Pedal Trim-Page 438
Brake Pedal Stop Lamp-Page 166
Brake-Master Cylinder, Bracket., & Pressure Indicator Switch-Page 70
Bumper Front/Rear Assembly-Page 178/179
Bumper Guards Front & Rear-Page 419
Carpet-front-Page 47
Cigarette Lighter-Page 165
Clip closure-non hardened steel-Page 5
Clutch Linkage Adjustments-Page 114
Clutch Pedal & Linkage-Page 112 & Clutch Pedal Trim-Page 438
Clutch Release Bearing-Page 111
Clutch Shaft & Push Rod-Page 113 & for 396 cu.in. Page 284
Console-Floor Assembly-Page 229-231
Console Gauges-Page 385
Console Oil Gauge Line Routing at Engine-Page 386, For Interior Routing-Page 385
Control Arms-Page 59
Cotter Pin Install Instructions-Page 5
Cowl Panel Piercing-Page 9/10
Cowl Seal-Page 136
Cowl Vent Grille-Page 37
Dash Trim Plate-Page 44
Dash Insulator Pad/Mat-Page 40
Defroster Ducts-Page 53
Disc Brakes-Front-Page 247
Dual Exhaust & Muffler-Page 360-367
Engine Mounts to Sub-Frame & Engine-Page 94
Engine Under-hood Lamp-Page 388/9
Exhaust Muffler & Hangers-Page 119
Exhaust Pipe (rear) & Hangers-Page 118
Fan Shroud & Radiator-Page 145
Fender Assembly-Page 135
Fender Emblems-Page 139
Fender Extension to Fender & Valance-Page 143
Fuel Pump-Page 99
Fuse Panel-Page 160
Gas Cap Assembly & fit up note-Page 121
Gas Gauge Metering & Rear Hose-Page 124
Gas Line & Clips-Page 123
Gas Tank Filler Neck (lower) & Cover-Page 122
Gas Tank Mtg. & Straps-Page 121
Glove Box Assembly-Page 41/42
Grille-upper, lower, center & emblem-Page 138
Header Panel-Page 137
Headlamp-Page 153
Headlight Switch-Page 165
Headlight Dimmer Switch-Page 166
Heater Control Assembly-Page 55
Heater Control Cables-Page 56
Heater/Defroster Assembly-Page 52
Heater Fan, Blower Assembly/Cowl-Page 52
Hood Catch, Support, & Latch Assembly-Page 144
Hood Hinge-Page 136
Hood Insulation & Retainers-Page 448
Hood under-hood Lamp-Page 388/9
Horn Relay-Page 155
Horn Low Note-Page 382
Hub Assembly-Page 60
Ignition Switch-Page 92
Inner Fender Mounting-Page 141
Inner Fender Seals-Page 140
Instrument Cluster/Instrument Cluster Lighting-Page 161/162
Instrument Panel Wiring Harness-Page 163/164
JL8 Brakes-Page 243
Leaf Spring to Front Bracket/Leaf Spring to Axle & Rear Shackle-Page 66/67
License Lamp Connector-Page 387
Master Cylinder Assembly & Balance Valve-Page 248
Mirror-Rear View-Page 44
Mirror-LH Door-Page 40
Motor Mounts-Page 94
Nut install that are open end type stamped 'MB'-Page 5
Oil Pressure Console Gauge Engine Block Fitting-U17 A3 Page 386
Parking Brake Alarm-Page 168
Parking Brake Connector & Rear Cables-Page 75
Parking Brake Pedal-Page 74
Parking Lamp-Page 153
PCV & Hose Z28-Page 443
Pedal Trim Plates-Page 438
Power Brake Assembly @ Cowl-Page 245
Power Steering-Page 373-379
Radiator & Clutch Fan-Page 256
Radiator & fan shroud-Page 145
Radiator Heavy Duty-Page 418
Radiator support to fender & fender support rods-Page 142
Radio Antenna-Front-Page 410
Radio Capacitor @ Voltage Regulator-Page 406
Radio Delete-Page 43
Radio Ground Straps V8-Page 408
Radio Receiver & Front Speaker U63 A2 Page 404
Radio Speaker Attachment-Page 404
Radio Speaker U80 A2 Page 416/7
Rag Joint Assembly & Caution-Page 129/130
Rear License Lamp-Page 172
Rocker Panel Sill Molding Spears-Page 45
Rally Sport (RS) Related-Page 423-437
Sheet metal gaps-Page 146-147
Shock Absorber-Front-Page 61
Shock Absorber-Rear-Page 68
Side Marker Lamps-Fender-Page 154
Smog Pump Z28-Page 442
Spare Tire & Jack Storage-Page 132
Speedometer Cable 4-speed-Page 241/322
Speed Warning Device-Page 383
Spoiler Front D80-Page 237
SS Hood & Emblems-Page 294
SS Paint Stripes-Page 295
Starter Motor Mtg.-Page 89
Steering Box to Column Assembly-Page 127
Steering Column Bolt-up-Page 44
Steering Column to Dash Seal-Page 128
Steering Column Mandatory Install Sequence-Page 130
Steering Wheel assembly Sequence-Page 129
Steering Wheel Deluxe-Page 368
Steering Wheel Tilt-Page 369
Sub-Frame Body Mounts-Page 50
Sway Bar & Links-Page 62
Tic-Toc-Tach-Page 384
Tie Rod Assembly-Page 126
Transmission 4-speed Cross-member Mount-Page 95
Trunk Compartment Light-Page 387
Valance to fender & fender extension-Page 143
Ventilation System/Dash-Page 51
Voltage Regulator-Page 92
Windshield Motor Switch-Page 42
Windshield Washer Jar-Page 38
Windshield Washer Nozzle & Hose Routing-Page 39
Windshield Wiper Motor, Arm, & Linkage-Page 36
Windshield Wipers-Page 37
Wiring-Alternator, Regulator & Relay-Page 156
Wiring-Floor Console-Page 233
Wiring-Console Gages Eng. Compartment-Page 386
Wiring-Courtesy Lamps-Page 167
Wiring-Engine V8-Page 158
Wiring-Headlamp, Park Lamp, Junction Block & Horn Relay-Page 155
Z/28 Paint Stripes-Page 444/445
