Can you help with this pulley list?
Here is a list of first gen pulleys that we don't have the diameter (list is also on-site). The alternator pulleys don't always have numbers stamped on them so it would have to come from an known original part.
Diameter is simply the OD of the part. (Originally, they would have been measured over steel balls because you care where the belt sits, not the OD.) Sorry about the column alignment, took work to even get it this nice!
SB is small block, BB is big block, DG is deep groove.
Pulley # Application Notes Year
1969433 Alternator L6, K76 68
3744043 Crank SB 67, 68
3755820 Crank SB 67
3770245 Water pump DG, Z/28 67, 68
3790337 Crank ext for ps L6 69
3844100 Alternator DG, BB 67
3850156 Alternator L6, 3843346 fan used 67
3853104 Crank ext for ps L6 with A/C 67
3853400 Crank ext for ps 230 cu in 67
3860457 Power steering 67, 68
3863108 Crank BB, DG, cast iron 67
3869978 Crank DG, cast iron 67, 68
3871253 Alternator L6, cast iron, 3843346 fan used 67
3874412 Crank BB 67
3874416 Crank ext for ps BB 67
3876846 Water pump 68
3876872 Crank ext for ps L6 67, 68, 69
3880886 Power steering L6 68, 69
3890419 Water pump 67, 68
3909815 Alternator Fan and pulley are one piece 67
3909817 Alternator 67
3916385 Crank ext for ps DG, Z/28 67, 68
3921923 Crank DG, BB 68
3927789 Water pump L6 with A/C 69
3932498 Crank w/ PS, unverified usage 69
3937788 Crank BB, unverified usage 69
3941105 Power steering DG 69
3947824 Water pump DG, BB 69
3955290 Crank BB 69
3955291 Crank DG, BB 69
3956664 Crank 69
Thanks!
Kurt
