Welcome,
Guest
. Please
login
or
register
Did you miss your
activation email
1 Hour
1 Day
1 Week
1 Month
Forever
Home
Help
Search
Login
General Discussion
RS Head Lamp Covers
« previous
next »
Print
Pages: [
1
Author
Topic: RS Head Lamp Covers (Read 6217 times)
marriest
Member
1969 Camaro Pace Car, 396 cu / 325 hp, #matching
RS Head Lamp Covers
on:
March 19, 2017, 10:14:10 AM »
Where should I look for the problem of my covers opening ok but do not close? Is there a diagram of how the vacuum system works and what the components are. That would help me with all the spaghetti under the hood and fenders.
Terry
Tweet
Logged
Terry
CRG Member
Re: RS Head Lamp Covers
Reply #1 on:
March 20, 2017, 01:10:11 AM »
The switch on the reserve tank may be in the override position. The covers will stay open so the lamps can be changed.
If that isn't it, the vacuum slider on the headlamp switch may be broken. Switch would have to be replaced. Requires someone with skinny arms.
Logged
marriest
Member
Reply #2 on:
March 20, 2017, 01:27:21 AM »
Is that what that switch is for? What position should it be in?
Logged
Terry
CRG Member
Reply #3 on:
March 20, 2017, 01:36:41 AM »
Normal operating position is to the right.
Logged
marriest
Member
Reply #4 on:
March 20, 2017, 09:16:49 AM »
I can't even see headlight switch let alone touch it. I have that large hands problem also.
Thanks!
Terry
Logged
Terry
ssl78
Member
Reply #5 on:
March 20, 2017, 08:41:10 PM »
Before you take out that switch I would bypass it and make sure that is what it is. I changed mine and it isnt easy
Logged
marriest
Member
Reply #6 on:
March 20, 2017, 09:35:22 PM »
Great idea! That is how I am dealing with the cowl induction switch and solenoid.
Logged
Terry
rich69rs
Hero Member
LF7/M35/Z22/Z87
Reply #7 on:
March 23, 2017, 09:26:29 PM »
This topic has come up several times in the past. If you search the site, you should find more than one post which addresses this topic with various diagrams, etc.
As a starting point, see attached and following post below.
Richard
Logged
Richard Thomas
1969 RS
rich69rs
Hero Member
LF7/M35/Z22/Z87
Reply #8 on:
March 23, 2017, 09:32:19 PM »
....and this Word doc.
Logged
Richard Thomas
1969 RS
marriest
Member
Reply #9 on:
March 29, 2017, 11:18:01 AM »
Thanks Richard this helps greatly.
Terry
Logged
Terry
marriest
Member
Reply #10 on:
April 19, 2017, 11:16:05 AM »
I broke down and replaced actuators that fixed the problem. Thank goodness for the aims diagrams. I had a devil of a time getting the cotter pins in on the headlight doors. No room to hold pins and install cotter pin. I had to tape the pins in place than install cotter pins. Any secrets?
Thanks for all the help!
Logged
Terry
Print
Pages: [
1
« previous
next »
General Discussion
RS Head Lamp Covers
