Author Topic: Bypass fitting 68Z  (Read 3392 times)
Tx-Z 302
Bypass fitting 68Z
« on: March 16, 2017, 03:24:46 AM »
Ok so my fitting is hex rather than square. Is it supposed to be brass or steel ? Played or natural? And lastly mine is not perfectly 90 degrees it appears to be aimed slightly downward?  Bent? Correct?  OTC part ?  No pic yet to post
The pump has just the small hole and the hub has a single set of holes rather than the eight hole set up?
Chris W
Re: Bypass fitting 68Z
« Reply #1 on: March 17, 2017, 10:34:14 PM »
Chris, here's an original that's in our 68Z. Some seem to have maybe a very slight angle but its not much and they are metal and painted as was the hose as well as they were on the engine assembly when painted at Flint.
