Author Topic: Help please 68 z28 leafs ?  (Read 80252 times)
Re: Help please 68 z28 leafs ?
« Reply #105 on: March 15, 2018, 06:34:58 PM »
Steering box is a sign but not proof of being a Z28.
Just start making a list of what parts with the car are correct for a Z28. The more the better.
Real proof is the drivetrain. Again, the more correct parts you have will improve your case of it being a Z.
I would have to go back but is the axle original and what code?
« Reply #106 on: March 15, 2018, 09:40:49 PM »
I'd be curious what idlers were used with those 8392 pitmans listed above. I'd assume 7581 idlers.....
Tx-Z 302
« Reply #107 on: March 16, 2018, 04:16:01 PM »
It's a multi leaf 12 bolt, BW code. It has 1981 dated 4.10 gm gears in It, but 1968 dated 4:56's in a box.
I have no clue if it's the original housing or not.
Chris W
x66 714
« Reply #108 on: March 16, 2018, 04:23:29 PM »
What's the rest of the code & what's the vin?....Joe
« Reply #109 on: March 16, 2018, 05:20:03 PM »
What’s the build date of the car on the trim tag?  And the axle assembly date? Axle assembly date is the rest of the stamped info after the BW.
If we can determine the axle is original, that’s a big step.
Tx-Z 302
« Reply #110 on: March 16, 2018, 06:01:30 PM »
BW0614G1
       E
Chris W
« Reply #111 on: March 16, 2018, 07:53:30 PM »
Chris, I went ahead and looked through the posts and pics.  I am 99 percent confident it is a Z28.
That is the correct axle for the car in my opinion.  What are the dates on the ring and pinion?
An inspection and report by Jerry M. would be enough proof for anyone.
Tx-Z 302
« Reply #112 on: March 16, 2018, 10:33:24 PM »
They are in my shop and I'm at the fire station. I'll get that info when I get off duty in the morning. Thx for looking, I sent tons of pics of the muncie hole in firewall and brake sytem etc etc... To Jerry he said it had to a Z or an SS and he feels that it is likely a Z, however he can't say without the inspection. And that's not exactly cheap.
Chris W
« Reply #113 on: March 16, 2018, 11:14:26 PM »
Where 4.56's an ss option?
BTY, my housing is dated april 24, and the car is 04d. Iooking through your posts, I'd agree pretty safe bet its a Z.
« Reply #114 on: March 16, 2018, 11:36:29 PM »
Yes you could get 4.56 with SS. L78 and L89.
Tx-Z 302
« Reply #115 on: March 16, 2018, 11:52:14 PM »
i love the cloud! i got my pics from the cloud, because im a computer guru! not!
Chris W
« Reply #116 on: March 16, 2018, 11:58:22 PM »
Those would probably be original. Date spread is a little larger than I would expect (Feb pinion, March ring gear, June assembly). But they are probably OK and are not common.
Tx-Z 302
« Reply #117 on: March 17, 2018, 12:30:32 AM »
I would have thought the ring and pinions would be matched sets ? As in both made in March or Feb?
Chris W
« Reply #118 on: March 17, 2018, 01:16:54 AM »
Usually but not always.
« Reply #119 on: March 17, 2018, 01:23:21 AM »
Just make a list of all the Z parts that you have and their dates. Proof will depend on the amount of evidence.
Depends on what you want to do on certification. If you can get others to come to the same place, Jerry can certify multiple cars. Certification fee won’t change but I believe the travel cost can be spread to multiple people if all done at the same time. But you would need to verify that with Jerry first.
