Author Topic: Horns  (Read 10276 times)
Horns
« on: March 07, 2017, 06:29:49 PM »
We added some info on horns to the site.
http://www.camaros.org/underhood.shtml#horns
Re: Horns
« Reply #1 on: March 07, 2017, 07:47:03 PM »
Wow, that article "blew" me away! :)
Re: Horns
« Reply #2 on: March 07, 2017, 08:50:45 PM »
Re: Horns
« Reply #3 on: March 07, 2017, 10:33:18 PM »
Very nice entry on horns (and batteries)..  both seemed to be very complete.
Re: Horns
« Reply #4 on: March 07, 2017, 10:45:15 PM »
Yup, I got a "charge" out of the battery info! :D
Re: Horns
« Reply #5 on: March 07, 2017, 11:49:50 PM »
Paul?  Did you get charged up..  or blown..  first?   :)
Re: Horns
« Reply #6 on: March 08, 2017, 12:18:17 AM »
Is not the fastener used to mount the horns somewhat unique? And should/could that information, if this is true, be added?
KevinW
Re: Horns
« Reply #7 on: March 08, 2017, 12:40:40 PM »
Kurt, great write up as usual! thanks
Bentley, per the AIM, the 69 horn bolt is the 3846202, the same captured washer bolt used in various fender locations, not rare :)  Can't say about 67& 68.
Re: Horns
« Reply #8 on: March 08, 2017, 01:59:44 PM »
I wonder if there are two part numbers involved - my original captured washers have a "serrated" bottom to them, which I thought was unique to the horn assembly - I have seen both, often wondered which was correct. Informal poll ?
Re: Horns
« Reply #9 on: March 08, 2017, 03:05:46 PM »
Seems like I remember a captured serrated washer as well on a couple other cars...
Re: Horns
« Reply #10 on: March 08, 2017, 03:11:59 PM »
1967 and 1968 used 3853846 which had the "toothed" washer (top picture). 1969 used the 3846202 which had the "smooth" washer (bottom picture).
Re: Horns
« Reply #11 on: March 08, 2017, 07:58:28 PM »
The 69 AIM notes the left side horn uses the 'prod. screw (catch asm to hood lock support asm)' and the right side horn uses 3846202, which has a note (4) against it which in the revision history is dated 10-28-68 stating 'was 3853846'. So the right side fastener is as Ed's numbers/pictures above.
Re: Horns
« Reply #12 on: March 08, 2017, 08:18:09 PM »
Quote
Same basic screw, just without any captured washer.
Re: Horns
« Reply #13 on: March 08, 2017, 11:17:40 PM »
Yes, very similar but with integral washer.
Re: Horns
« Reply #14 on: March 09, 2017, 02:46:43 AM »
Quote
Ed/Tim,
Thanks for clearing that up. I looked at my originals on the 01C X77, they are correct, it's the Pace Car that is wrong. It had incorrect horns on it when I bought it in '94, I replaced the horns with the right part #s and dates, but I picked the wrong bolts (68's) out of spares when I reassembled them. I'll switch it back based on this -
