Author Topic: 124379N568469 - Z28 Engine Block  (Read 9831 times)
« on: February 28, 2017, 12:25:40 AM »
Your 302cid/290hp Z/28 engine block is on eBay...
Engine pad is stamped: V1218DZ
Partial VIN stamped by oil filter boss: 19N368469
Block casting number: 3932386
Block casting date: L 12 8
Seller id: swartzysautoemporium
Seller location: Waterport, NY
http://www.ebay.com/itm/1969-Chevrolet-Camaro-Z-28-302-Chevy-Small-block-V8-engine-DZ-Code-3932386/142292638994?_trksid=p2047675.c100005.m1851&_trkparms=aid%3D222007%26algo%3DSIC.MBE%26ao%3D2%26asc%3D41393%26meid%3D43c3ff541d374d88b660dfd53c28cefd%26pid%3D100005%26rk%3D1%26rkt%3D6%26sd%3D142279104143
« Last Edit: February 28, 2017, 04:25:50 AM by KurtS »
Boston14
Re: 9N568469 - Z28 Engine Block
« Reply #1 on: February 28, 2017, 01:06:47 AM »
Partial VIN is probably 19N568469, at least that fits better date wise ..............
« Last Edit: September 12, 2017, 01:27:03 PM by bertfam »
boston14
1969 SS/RS 350 Convertible
Dusk Blue Z
19N568469 V1218DZ Block
« Reply #2 on: September 11, 2017, 11:33:09 PM »
This is another engine from my fathers collection he stashed away years ago , a 1969 Chevrolet Camaro Z/28 302 engine , chevy small block motor . This empty motor�Block has the following casting numbers�# 3932386� date coded L128 , stamped V1218DZ on the front stamping pad , the Vin�stamping by the oil filter looks to be 19N368469. The casting numbers in the timing area are : 371 G47 386 and HB outside the timing cover area . Casting numbers in the bell area are : 636 678 371 386 H3 . Casting numbers near the oil filter are :371 386 62N .
 ���� This 4 bolt main block was large journal 2.45 , and used for 1969 350 Corvette 300/350hp. , Camaro 1969 302 z/28 , and 1968 69 327 Passenger car nova chevelle .
 ��� This one as my uncle told me the story� goes , my father worked in the Oldsmobile dealership garage and had friends that worked at the chevy dealerships garages . He Got this block from one of the friends that worked at the chevy dealership . A guy had bought a 1969 Camaro Z/28 302 car new�put about� 5000 miles on it , he walked out to it next day and it was leaking oil on his garage floor . He took it back to the dealer to fix the oil leak they could 'nt fix it so�Chevrolet sent him out a warranty replacement block . They took every thing off the old block and put it in the new one and put the new warranty block in the car and away he drove.
 ���� My uncle said the problem with the block was the push in plug above the oil filter { as pictured } , and if you look at the picture it looks like the mechanic tried to peen it over more to seal it�, But it must not have worked .
 ��� This has been sitting for years�, about 35 or 40 , �It has surface rust from sitting around , the cylinder walls were greased� at one point and the spots where they were surface rusted it cleaned right of for the most part with a wire wheel in a drill { as pictured}.My father also greased the lifter bores again many years ago.
 ����� I have more pictures if needed , if you have any questions please ask , and if shipping is needed ask I might be able to do something .� I also have on another auction a mostly complete 1968 MO code z/28 302�engine, if you have any questions call 585 -682-5595 no text please this number don't get them .
https://rochester.craigslist.org/pts/d/1969-chevrolet-camarochevy/6254647273.html
« Last Edit: September 12, 2017, 01:26:50 PM by bertfam »
1969 Z/28 Legends Certified
1969 Z-10 350 4 speed
Z28Project
Re: 19N568469 V1218DZ Block
« Reply #3 on: September 12, 2017, 12:03:54 AM »
I wish it was about a week earlier on the stamp!  I just had an engine built for my Z but not close to being date correct.
Probably 19N568 on the VIN.  That would have probably been in a 12C car, and mines a 12B.
Close, but no cigar!
« Last Edit: September 12, 2017, 01:26:37 PM by bertfam »
John
69 Z/28 NOR 12B X33 H.O. 'Ex-Racer'
« Last Edit: September 12, 2017, 01:27:21 PM by bertfam »
« Reply #5 on: September 12, 2017, 01:24:49 PM »
I merged both threads into one.
