Author Topic: Original 67 Turn & Haard Flashers  (Read 4799 times)
big iron
« on: February 25, 2017, 02:22:28 AM »
Need information on types of turn and hazard flashers used in both RS and non RS 67's.
I have part #'s from 67 AIM but they do not translate to type numbers and have no idea what the optional flasher # is used for, except maybe for RS.
Example: Tung-Sol 552
                  "     "   323
                  "     "   224
   "          Signal-Stat  175
   "              "     "      145
So if any members with a 67 RS with original flashers would chime in I would greatly appreciate the replies.
Bob
big iron
Re: Original 67 Turn & Haard Flashers
« Reply #1 on: February 25, 2017, 10:08:59 PM »
I think this topic needs to be in Originality!
Bob
« Reply #2 on: April 19, 2017, 03:06:44 PM »
Hi Bob,
   While I was installing my wiring harness into the convertible I happen to remember this thread.
Attached are pictures of flashers from my 67 04B LOS and 05B NOR, both with rally sport.
I'm not sure if RS has anything to do with which flasher was used.
  The LOS flashers were in the car when I bought it in 1980 with about 53000 miles. Even then it sat in a garage for 6 years before being sold to me.
I only put 5000 miles on the car since I've owned it and never had flasher issues. The yellow flasher housing is plastic.
  The NOR has what looks like its original fuse panel mounted flasher and it has the 'DOT' stamp. It was there since I bought the car in 1979. That panel still has many color coded original fuses. The under dash flasher is a recent replacement (not pictured).
1968 Z28
« Reply #3 on: April 20, 2017, 01:33:16 AM »
I would think that the DOT spec flasher would be a replacement.  The SAE specs should have been in effect in 1967. I don't believe the DOT specs came about until later.
Jerry G.
Z28-1968-07C-Norwood
2nd. Owner, 38,000 miles
