Author Topic: 1969 camaro radio antenna delete  (Read 6754 times)
Olympic gold
« on: January 23, 2017, 10:28:50 PM »
i would like to get rid of my unused radio antenna with out leaving a hole in the the fender. and not any body work or paint. i would even consider just replacing it with a retractable one. is there any products on the market to fix this.  Thanks
1971ls6
Re: 1969 camaro radio antenna delete
« Reply #1 on: January 26, 2017, 02:10:12 AM »
The factory used a plug to fill the hole, all fenders had the hole
69 Copo 12.28 @ 117.50 4spd on polyglas
71 LS6 vette 12.31@118 mph PSMCDR
« Reply #2 on: January 26, 2017, 02:32:46 AM »
Quote
Well, no. Only cars ordered with a radio (and without the RPO U73 rear antenna) got the hole in the front fender. The drilling instructions are in the AIM, UPC U63/U69, sheet B1, view A.
Quote
If you don't want the hole, you'll need to either fill it, plug it or buy a new fender. But I'm confused. You want to "get rid of the antenna", but "replace it with a retractable one". Those statements are contradictory!
69 Zee
« Reply #3 on: January 26, 2017, 03:38:23 AM »
Sounds like you don't use or have a radio and you just want to plug up the hole without doing any bodywork... yes ?  Reason for suggesting a retractable antenna, then yes that's your best option w/o it looking botched.
Overall that just kinda seems odd though  ???
Darrell
« Reply #4 on: January 26, 2017, 04:25:23 AM »
They have little chrome plugs for the fender hole.
« Reply #5 on: January 26, 2017, 09:47:12 AM »
Yep. Try searching for chrome antenna delete cap.
Olympic gold
« Reply #6 on: January 29, 2017, 06:06:46 PM »
sorry for the confusion but i just want something that looks better than my crooked 3 foot tall wobbly antenna. thanks for the suggestions
69 Zee
« Reply #7 on: January 29, 2017, 10:36:04 PM »
You can replace the mast ... simple,  if your wanting it to remain cosmetically correct.
Darrell
