Author Topic: Re: 68 ss ID #2  (Read 10420 times)
jmalara
Re: 68 ss ID #2
« on: January 14, 2017, 12:10:32 PM »
OK guys.  I've given up on that car as the owner just doesn't want to show it.  I think he knows I'm on to him.  I have a different car I'm interested in.  Attached is a pic of the cowl tag.  What can folks tell me about this car?
The pic is too big to post.  I have to figure out how to compress but here is info from the cowl tag:
             04D
ST       68-12467     NOR121835     BODY
TR       712                      -2          PAINT
What does the dash mean on the body paint section?
John
jmalara
Re: Re: 68 ss ID #2
« Reply #1 on: January 14, 2017, 01:42:03 PM »
Here they come...
jmalara
Re: Re: 68 ss ID #2
« Reply #2 on: January 14, 2017, 01:42:58 PM »
More...
jmalara
Re: Re: 68 ss ID #2
« Reply #3 on: January 14, 2017, 01:46:14 PM »
Interesting.  Looking at the motor, it was pointed out on the last car I was looking at that the alternator was on the wrong side for an original.  This one is the same.  I know the engine on this was rebuilt also.  I will get some pics when I look at the car of the block stamp to make sure it is the original block.  Not sure why it seems common to rebuilt differently from stock.
Re: Re: 68 ss ID #2
« Reply #4 on: January 14, 2017, 03:15:27 PM »
 Years ago when I used to drag race, a few racers that had '67/68 Camaros converted to a '69 alternator setup for the sake of having a shorter belt and less chance to throw it at the end of the track.
  I see NY plates, what part are you in?
x66 714
Re: Re: 68 ss ID #2
« Reply #5 on: January 14, 2017, 03:18:37 PM »
I like the looks of this car better than the first one....Joe
jmalara
Re: Re: 68 ss ID #2
« Reply #6 on: January 14, 2017, 03:34:34 PM »
I live in Putnam County, about 45 minutes from White Plains.  This car is in Long Island.
And this car is a lot more $$$$$ than the other car.
Re: Re: 68 ss ID #2
« Reply #7 on: January 14, 2017, 03:36:30 PM »
-2 means the body color was special paint with a black convertible top.
http://www.camaros.org/numbers.shtml#ExteriorColors
Check that car over with someone you trust. Looks like a decent car from the pics. But look for rust or repairs.
Does it have a 12 bolt and if so what are the numbers and letters stamped on the front edge of the passenger side axle tube?
RS convertible is awesome, if you like convertibles.
Re: Re: 68 ss ID #2
« Reply #8 on: January 14, 2017, 03:46:06 PM »
From the looks of the pictures I am guessing the car is in Suffolk County on LI. I live in Manorville (east Suffolk).
jmalara
Re: Re: 68 ss ID #2
« Reply #9 on: January 14, 2017, 04:33:30 PM »
Thanks Guys,
So the car is now Fathom Blue with a white convertible top.  With the negative sign, how do I tell what color it was originally?
Mike,  Sounds like you are close.  How about a little road trip?  I'm a newbie and sure could use an experiences set of eyes to inspect.  I'd be willing to pay the going rate also.
JM
Re: Re: 68 ss ID #2
« Reply #10 on: January 14, 2017, 04:41:09 PM »
It could be Fathom Blue original paint.  Could be.
From the exterior colors section I grabbed this paragraph.  By the time that car was built, Fathom Blue was not a standard color.
In 1968, two colors, Tuxedo Black and Cordovan Maroon, started the year common to both Camaro and Corvette. In January 1968, three additional Corvette colors were added to Camaro, with specific marketing attention given to the fact that they were Corvette colors applied to Camaro. These three were Corvette Bronze, LeMans Blue, and British Green. (In addition to these three, Rallye Green was another mid-season Camaro color addition. Together they replaced Fathom Blue, Grecian Green, Palomino Ivory, and Tuxedo Black for the remainder of 1968.) As a result, Corvette shared a total of five colors with Camaro in 1968.
x66 714
Re: Re: 68 ss ID #2
« Reply #11 on: January 14, 2017, 06:21:04 PM »
How do you know what color it was originally?
Doubtful anybody did a full restoration on the car. That being said, you would look in areas beyond the last paint job.
Under moldings, behind décor panels, etc....Joe
Re: Re: 68 ss ID #2
« Reply #12 on: January 14, 2017, 06:51:17 PM »
It's possible that the RS option was added. There is no vacuum tank under the hood for the vacuum operated headlamp doors and the car has standard rocker moldings.
jmalara
Re: Re: 68 ss ID #2
« Reply #13 on: January 15, 2017, 11:20:01 PM »
Of I look at the picture of the motor and enlarge it a bit , by the windshield washer resevoir there are two holes in the metal.  Could that be where the headlight vacume was mounted?  Would there be a switch in the car somewhere that I can check.
I will be down to see the car tomorrow.
Also, when I look at the picture fro the side, the wheel wells have a chrome strip.  Isn't that RS accenting?
Jm
Re: Re: 68 ss ID #2
« Reply #14 on: January 15, 2017, 11:43:11 PM »
Jm
I see nothing under the hood that is evidence or suggests this car having OE RS including the washer reservoir is in the wrong location.
The headlight switch should have vacuum hose connections.
Wheel well bright work is evidence of the style trim option that was also part of the RS option, but does not exclusively point to an RS equipped car
