Author Topic: Original Born with Battery Trays LOS NOR  (Read 41645 times)
Re: Original Born with Battery Trays LOS NOR
« Reply #30 on: January 25, 2017, 11:20:30 PM »
Steve, what is the full name for MCCP?
« Reply #31 on: January 25, 2017, 11:51:15 PM »
I'll take better pics but you are correct almost dead-on.
Yes what makes this one even better is the angled nuts are correct. We know they are not seen when battery in place but that is a good one! That was 8 years ago and my searching did not come up with that one so hopefully its still around.
« Reply #32 on: January 25, 2017, 11:58:10 PM »
67 DaveV same design as Jon's No tab-two sharp points w/correct angled nuts
67 Jon’s 1100 mile take off-No Tab-two sharp points w/correct angled nuts
67 11A LOS Has tab but not as pronounced as many. Robert
68 02D NOR Has tab Randy (Dutch)
68 03D NOR Has tab Darrell
68 04D NOR Has tab Janobyte
68 05E NOR Has tab Danny
68 06A NOR Has tab DaveV
68 07C NOR Has tab JerryG
68 07D NOR Has tab Skip
69 Oct68 LOS Has tab asm69
69 LOS Has tab Mike1971
69 NOR Has tab Mike1971
69 11A NOR No tab Has angled nuts & orig. battery hold down clamp. Noyenko
69 Has tab but not as pronounced as many. Noyenko
69 01C NOR Has tab Jude
69 02D NOR Has tab SteveS
69 03B NOR Has tab SteveS
69 03E NOR Has tab Eldon Has one sharp point with tab
69 08C NOR Has tab Bullitt65
69 09A NOR Has tab (late built) Robert
69 09D NOR Has tab (late built) Skip
Hans L
« Reply #33 on: January 30, 2017, 06:07:10 AM »
Per the descriptions provided, pretty sure the bat tray off my Z is original.  '69, Van Nuys, 04B build.   73K original miles.
Gonna take some work/clean-up to make it look good though....
'69 Chevelle SS 396 4 Speed
'70 Camaro SS L78
Steve Shauger
    • Vintage Certification
« Reply #34 on: January 30, 2017, 01:40:40 PM »
"Steve, what is the full name for MCCP?"
McHenry Classic Car Parts 815-648-1700 Ron. There may be other vendors but that's where I purchased mine.
Steve Shauger
« Reply #35 on: January 30, 2017, 04:26:56 PM »
I called and spoke to Ron; after checking he said the supplier for that battery tray was no longer producing them, and that the AMD was the only producer....  That's a shame as I was very impressed wtih the accurate detail that supplier had designed into their tray!   the AMD battery tray is like most of the AMD stuff... at the large scale, they do a pretty decent job, but then they fall down on the small details (like the orientation of the nuts)...
« Reply #36 on: January 30, 2017, 04:56:41 PM »
The good news is with some modifications as outlined and battery in place it can be made to look very correct.
69 04B LOS Has tab Hans
dutch
« Reply #37 on: January 31, 2017, 03:09:02 AM »
Chick - did try and post a picture of mine here tonight - but didn't have any luck.. Suffice to say the picture that I couldn't attach shows the angled nut on the tray bottom as I mentioned previously and the tab on the end slightly angled.  I finally gave up -you'll have to take my word for it!
Couldn't believe how scruffy my tray actually was when I looked closer after removing the battery, which should have been done months back - but after 49+ years..
Randy
« Reply #38 on: January 31, 2017, 10:40:36 PM »
Thanks for confirming those details Steve; pity they're no longer able to source that part, but as Chick points out, the AMD version is very close with a minor tweak.
KevinW
« Reply #39 on: February 04, 2017, 01:26:36 PM »
Wonderful thread!  But one question, do the 69 hold downs have the two dimples too?  I am sitting in front of my computer with a NOS battery tray with sticker 3893882 and can see the differences noted here.  But it looks like there is extra metal on the hold down tab.  So I think with a little trimming, it can approximate the tab.  My GM hold down does not have the dimples but has the rocketship stamp like a pic here.  Maybe a little time in a press will fix that :D
« Reply #40 on: February 11, 2017, 01:42:27 AM »
On the 69 models I've looked at that were original cars they have had the two dimples. Skip's late 69 09D Camaro has it and our March built 69 Nova that we ordered in Feb.69 have it for a quick two examples. Used on many GM cars over several years. The hold down that has the "rocketship stamp" (good one) I've only noted on very old service replacements. Survivor cars or used original two dimple hold downs seem to have a single stamp. "C" is a common stamp found.
On the tray Kevin, I actually did that to a GM service replacement tray I had and probably in a car it would look the part. What it would not have is the slight kink/bend in that tab area but possibly a press could accommodate that.
KevinW
« Reply #41 on: February 11, 2017, 12:32:20 PM »
Thanks Chick!  I will be on the hunt at the swap meets!
Edgemontvillage
« Reply #42 on: May 19, 2018, 01:03:02 PM »
Just completed the restoration of my original tray from my 69 Norwood 2B Z/28 (with tab).
« Reply #43 on: May 19, 2018, 10:29:19 PM »
Looks great Lloyd, as always. Are you enjoying this project as a full restoration, rather than detailing and preserving a survivor?
« Reply #44 on: May 20, 2018, 12:01:28 AM »
Looks great Lloyd! How about a picture before restoration? :)
