Author Topic: rear antenna  (Read 23647 times)
67conv6cyl
rear antenna
« on: January 10, 2017, 03:48:32 AM »
Is there a difference in the front antenna mast from the rear antenna mast. dose any body have an original picture?
67jeffreyt
Re: rear antenna
« Reply #1 on: January 10, 2017, 12:21:45 PM »
Front is a fixed mast, the rear is extendable and from what I have read, fixed mast was am/FM and the extendable was am only.  But I'm not the official word on this.
67 ss/rs camaro currently
68 prostreet Camaro 9.60 1/4 mile
68 Rallysport, first car high school
89 rs camaro convertible, made readers rides super Chevy
Re: rear antenna
« Reply #2 on: January 10, 2017, 02:33:57 PM »
The AM mast is the same (P/N 3876412) for front and rear, but the bezel and a few other parts are different. Check your 1967 AIM for more info.
67conv6cyl
Re: rear antenna
« Reply #3 on: January 10, 2017, 03:15:33 PM »
Thanks for the picture, however the antenna base in the picture looks different from what I thought it was supposed to look like, is a 68 different from a 67
Re: rear antenna
« Reply #4 on: January 10, 2017, 03:29:22 PM »
Quote
No, both years used the same parts.
Re: rear antenna
« Reply #5 on: January 10, 2017, 03:48:25 PM »
Ed do you have a better pic?  Maybe its my eyes but it doesnt look correct..
Re: rear antenna
« Reply #6 on: January 10, 2017, 04:09:14 PM »
No, I don't have many cars with U73, but maybe these two will help. Notice how they appear to be slightly different and it may be because antennas had multiple suppliers.
HawkX66
Re: rear antenna
« Reply #7 on: January 10, 2017, 04:10:25 PM »
Is the OE Darrell? I see it has the spoiler.
Dave
69 SS396 X66 L34 M21 BS
Z23 711 U17 Hugger Orange
Semper Fi!
Re: rear antenna
« Reply #8 on: January 10, 2017, 04:15:35 PM »
Yes spoiler was added.. And Ed that last pic you just posted has the antenna in the wrong location.
This one appears to be correct and almost looks like the mast is bent..?.  Interesting..
Re: rear antenna
« Reply #9 on: January 10, 2017, 05:12:21 PM »
 I have the rear antenna (AM) on my 67 convertible. It stands with a very slight pitch backwards when viewed from the side and the mast is supposed to have about a 6 degree tilt when facing the rear of it and looking forward. Let me take a picture of it.
Re: rear antenna
« Reply #10 on: January 10, 2017, 05:34:35 PM »
Quote
Actually Darrell, if you look at the AIM (see attached), that's the only car in this thread with the antenna in the semi-correct location!!! The fore/aft hole should be approx even with the trunk gutter lip and it appears that all the other cars have it placed too far rearward.
Re: rear antenna
« Reply #11 on: January 10, 2017, 05:37:20 PM »
Less than a month old..  Hard to see but the antenna is straight up.
Re: rear antenna
« Reply #12 on: January 10, 2017, 05:37:58 PM »
Here's another picture of the blue car. And like the others (except for the black car), it's too far rearward. At least in comparison with the AIM. And according to the AIM, "The antenna should lean inboard approx. 4 degrees (Ref.) when viewed from front of car & stand vertically when viewed from side of car".
Darrell, do you have another picture showing where the antenna is mounted on your car in reference to the mounting location in the AIM?
Re: rear antenna
« Reply #13 on: January 10, 2017, 05:46:23 PM »
Ill have to look Ed but I wanna say there is a reinforcement plate in the corner or something where they are showing in the AIM to put the hole..  Ill look next time I am in the trunk of the green car..
Re: rear antenna
« Reply #14 on: January 10, 2017, 05:49:45 PM »
Best I have at this point Ed..  Pic was from the early 90's..  Also Ed; you and I both know that there are errors in the AIM..   ;D
Edit:  here is a pic from inside the trunk.
