Welcome,
Guest
. Please
login
or
register
Did you miss your
activation email
1 Hour
1 Day
1 Week
1 Month
Forever
Home
Help
Search
Login
Originality
68 rs ss am fm multiplex radio
« previous
next »
Print
Pages:
1
2
3
All
Author
Topic: 68 rs ss am fm multiplex radio (Read 17891 times)
lilfighta
Member
Re: 68 rs ss am fm multiplex radio
Reply #30 on:
February 03, 2017, 06:21:25 PM »
Hi Paul do you happen to have this box that goes under console door ? Im having alot of problems getting the label
correct and centered. The box itself sits more to the driver side left. Under the door there is upper and lower plastic
lines and to the left you have the brackets and you have to center it but without the box like me i cant get measurements
correct especially where the dials come out on the outer of the console door.
Thank You Mike
Logged
lilfighta
Member
Reply #31 on:
February 03, 2017, 06:24:01 PM »
Hi made mistake to the right passenger side is the bracket that takes up space to
thx
Logged
fsc66
Member
Reply #32 on:
February 04, 2017, 02:49:49 PM »
I have a 1966 Impala SS with console multiplex which is a slightly different unit. Mine is centered on the console door, left to right plus I have the original dealer installtion instructions with measurements. I do not have the assembly manual for a 68 Camaro but possible the measurements for the decal isstalltion are in there?
Logged
fsc66
Member
Reply #33 on:
February 04, 2017, 03:01:13 PM »
Mike,
Maybe write this guy and ask for measurements?
http://www.ebay.com/itm/1968-1969-CAMARO-Console-Multiplex-ORIGINAL-RARE-/182316594960?hash=item2a72ea7710:g:ED0AAOSwmLlYA~4O&vxp=mtr
Logged
lilfighta
Member
Reply #34 on:
February 04, 2017, 03:12:13 PM »
Hi Paul the impala box should be the same since they use the same label.If you get a chance can you post the instructions
here actually the measurements. I can probably figure it out from there
thx
Logged
fsc66
Member
Reply #35 on:
February 04, 2017, 05:46:26 PM »
Mike, I'm sure the multiplex box is the same but it mounts centered in the console door from left to right, whereas the 68 Camaro mount is off-set. Which measurement are you thinking will help you?
Logged
lilfighta
Member
Reply #36 on:
February 05, 2017, 06:24:27 PM »
Hi Paul if you look close at the picture of cover that i posted you will see 2 lines one on bottom of box and one on top built into the cover .
Then if you look at the hinge side you might be able to see the bracket. The box probably sits center of the 3
things. So if i can get the size of the square box which would probably be around 31/2 to 4" square. Not sure though
and the distance between the top of box and side of box to center of volume control button which looks to be around 3/4".Then I probably could center the box correctly. I wish i can find old garbage one that doesnt work so i dont have to bother people and get measurement .
Thx Paul
Logged
lilfighta
Member
Reply #37 on:
February 05, 2017, 06:34:42 PM »
This is what I need
Logged
Print
Pages:
1
2
3
All
« previous
next »
Originality
