Author Topic: 1968 radiator removed from Z28  (Read 9603 times)
ssl78
« on: December 26, 2016, 07:01:26 PM »
 I have a 1968 radiator I removed from a 1968 Z28 it is a 4 speed radiator but according to the tag it should be a auto radiator. Anybody ever see this before?
Re: 1968 radiator removed from Z28
« Reply #1 on: December 26, 2016, 09:25:36 PM »
Whats the tag between the UI tag and the OF stamping?  Was this from a LOS or NOR car?  Build date etc.
ssl78
« Reply #2 on: December 26, 2016, 09:40:11 PM »
It says the name of the company who recored the radiator. It was a norwood car
« Reply #3 on: December 26, 2016, 09:46:19 PM »
Confused! Yea I do it a lot! Had the radiator been re-cored and in the car when you took it out or you had it re-cored after taking the radiator out? I'm just wondering if there is any possibility the tag was switched when re-cored by the radiator shop.
ssl78
« Reply #4 on: December 26, 2016, 09:53:24 PM »
It was already recored but the codes on the tanks match the tag. It looks like the one tank had the indentations for the trans cooler fittings but were never drilled out. I would think if it was a replacement tank it would not have a factory code.
« Reply #5 on: December 26, 2016, 10:23:42 PM »
OF tank is for an auto trans sb car..  I would assume that the goof was at Harrison and Chevrolet just happened to install it (without looking at it or they were running low);into a Z as it could have ended up in any manual trans 6 or sb 8 cylinder.  Just another one of those anomalies of human error in a production line environment...  Just my $0.02
« Reply #6 on: December 26, 2016, 11:34:46 PM »
Their is a shop tag to the right of the OF stamp. The radiator was worked on and may have had a tank replaced. Happens all the time.
ssl78
« Reply #7 on: December 26, 2016, 11:46:49 PM »
yes it was recored but would it they changed the tank I doubt it would be a gm coded tank
« Reply #8 on: December 27, 2016, 12:24:15 AM »
Long ago shops had parts in stock simply due to high volume repairs. The body shop I worked in years ago had an attached radiator shop. What happened to your radiator is anyone's guess. If you have a particular requirement, I'd suggest calling Glen-Ray Radiator. He's done work for me and he is quite knowledgeable. He also has NOS Harrison 3 and 4 rows, coolers and used tanks in stock. Easier to call him for all he has to offer.
I now save every tank from cars I scrap; too bad I did not do so long ago when we took all these cars for granted. Now I just have my own radiators made.
« Reply #9 on: December 27, 2016, 01:54:37 AM »
  The original tank may have been damaged, cracked or crushed. My buddy that has a radiator shop saved used tanks for replacement. the code means nothing to them, just that it fits and doesn't leak.
« Reply #10 on: December 27, 2016, 02:03:49 AM »
I could care less what car it was pulled out of...  The interesting point for me is that the tank is coded for an auto but the tank isnt punched..
ssl78
« Reply #11 on: December 27, 2016, 02:08:22 AM »
That's exactly what I was wondering about and on the tag it also says it should be punched so it can not be a wrong tank installed.
« Reply #12 on: December 27, 2016, 03:22:04 AM »
Yes that is exactly correct...
That drivers side tank is an unpierced auto tank... it has provisions for the fittings for the autotrans cooler. They just are not there.
« Reply #13 on: December 27, 2016, 03:55:20 AM »
I dont see one but is there a letter date code between the O & F?
ssl78
« Reply #14 on: December 27, 2016, 04:21:44 AM »
yes a H
