Paul, a good friend of mine, bought his 66 L78 chevelle brand new with a cowl plenum setup, he still owns the car today, unrestored with about 30,000 original miles on it.
I've always thought the setups were cool looking, and neat to see on 67-68 Camaros, but I've always had mixed feelings putting the setup on any car after 68. Since 69 Camaros had the benefit of the ZL2 option the cowl plenum deal sort of went away as far as production cars are concerned.
My 69Z being an original flat hood car, the thought of a cowl plenum setup is appealing, but if I wanted a fresh air setup, a ZL2 hood would go on it. I couldn't bear to hack up the firewall. If it were a 67 or 68 however, I'd have a cowl plenum on it no question, whether it added power or not.
My 70 formula is a ram air car, however it grabs air front and center just over the bumper of the car. Said to be one of the more effective setups from the muscle car era, but seldom seen today (293 made in 1970) I've raced the car in PS form for years, and found that if I blocked or even restricted the fresh air the car slowed down nearly 2 tenths and would lose about 1 mph. I found there is A LOT of air being forced in the air cleaner base when at speed. It would blow my PCV filter out of it's plastic container and would be laying in the back of the air cleaner base after a pass. I ended up wire tying the little filter into the base so it would stay put. I even tried removing the air filter once looking for more ET, and that absolutely killed the performance, slowing the car more than 3 tenths. My theory was that so much air turbulence was being forced in there it really screwed up the carbs metering ability, the filter helped to slow and straighten the air. Replaced filter and the car went right back to normal ET and MPH. This is just to provide one example of a fresh air setup on a bone stock 400/335 hp car that runs low 13's at 106 mph on stock F70-14's. On this particular car, with this particular setup, it's effective.
On a setup that grabs fresh air at the windshield, it might work, but I'm sure it won't be as effective as the design on my Pontiac. I'm going to test the theory on my Z though, at the track with the ZL2 setup and without. I'm predicting I won't see the differences I see with my Pontiac. Especially since the Z is such a small engine anyway.
