Brake lines where a match to originals requiring minimal tweaking. Was going to run the front to rear today, along with the fuel line. Tired, feeling lazy, and really don't see the priority as I'm dropping the rear end anyway in the Spring.
The heater core. Dad recommended having it pressure tested, as no coolant has ran through it in 37 years. Actually,more like a better have it checked out! Appears like new,
however, when plugging bottom elbow, and blowing through top, flood of air. Bottom tube weld has a hairline crack. No big deal, local shop is rectifying the problem...and pressure checking it. Good time to lube the cables, which have never been used, and order a new firewall pad. Age seems to catch up to those pads.
Since this is Garage Talk, I'll keep babbling on. Speaking of Dad, found out mid-November he has cancer in one of his kidneys, other one may not be functioning.Although no sx's of poor function. After a roller coaster ride of inconsistent information from one hospital/surgeon, it was second opinion time. Far better prognosis, with a good set of consistent options which make sense.
So what does excite me concerning the Z, is seeing him pull gears in it again, like when I was a kid. 4:88's and loud
He's only 70, not ready to be out to pasture just yet.
